P0455, and nothing else
Old Jun 20, 2014 | 06:12 PM
The Clevite Kid's Avatar
The Clevite Kid
St. Jude 15 Year Donor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15-'16,'17,'18-'19-'20-'21-'22
Default P0455, and nothing else
A search shows not posts since last year. What is the current thinking about the cause and cure of a P0455 (check engine light) with no other codes, and no GAS CAP message?
Thanx for all the opinions of our colleagues.
Old Jun 20, 2014 | 08:53 PM
Red06Vette's Avatar
Red06Vette
Just had this on my 06 after replacing gas cap, appears it was the vent solenoid located on passenger side frame rail forward of rear axle. You will need to take out passengers side inner wheel well to get to large hose from evap canister. Job is a PITA, but code has not return since.
Old Jun 20, 2014 | 09:03 PM
saplumr's Avatar
saplumr
It could be the evap system or it could be the simple gas cap. Remove it and put it back on, sometimes things can be simple. If not it's more than likely the cannister.
To P0455, and nothing else
