Fast Intake thoughts!!! please read.
Old Jun 25, 2014 | 10:56 PM
shawnaj7731's Avatar
shawnaj7731
Default UPDATE :Fast Intake thoughts!!! please read.
Hey Guys here is my question my current said setup is listed below. Will switching to a Ported FAST 102 LSXR intake and 42lb injector will it make a significant difference in HP or TQ.. I am looking at 1500 total cost or will it not be worth the money.
05 C6 LS2...Current Numbers are 492 rwhp and 451Rwtq Afr 12.7 area.
Radical ported Peaks Speed shop intake
ported 90mm TB
Texas speed 225 as cast heads
Morel lifters
stocker rockers trunion upgrade
OBX LT headers NO cats
SLP loudmouth II axle back
Custom grind cam 231/243 .617/.623 @ 113 lobe seperation
UD power bond 25% pulley
Vararam Cai intake
Stock 36lb injectors
Old Jun 25, 2014 | 11:11 PM
ACLR8R's Avatar
ACLR8R
I would say it should be enough to push you over 500.
Old Jun 26, 2014 | 11:49 AM
lebvette's Avatar
lebvette
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18-‘19-'20-'21
I say......keep your money, or put it into some lower gears. I don't think you will go much over what you have with your ported stock intake. It will help a little under the curve......$1500 worth....I wouldn't think so, but it depends on what you want.
You seem to have more than you can get to the ground, now. Gears or sticky tires will get better results.
The Fast does look good setting on top of the motor, tho.
Old Jun 26, 2014 | 05:27 PM
johnnystock's Avatar
johnnystock
You already have a beast. Depends how bad you want that magical 500rwhp number Those last HP are expensive, theres no way around it.
Better headers? Like ARH 2'' or LG could get you there IMO. Cutout?
Old Jun 26, 2014 | 09:13 PM
shawnaj7731
Well I bit the bullet I spoke numerous people locally and they all said it will improve a lot more with the ported fast 102 and 42lb injectors. My current DC is 99 at WOT. So I am assuming my tuner can make the magic happen once I get all the parts in. So now I need to figure out what injectors to get. I heard FIC are the easiest and cheap in $$$.
Old Jun 26, 2014 | 09:44 PM
saplumr's Avatar
saplumr
My guess is if you already have a ported intake mainfold you'll pick up maybe 15 with the FAST. It may or may not be money well invested.
Old Jun 27, 2014 | 09:46 AM
lebvette's Avatar
lebvette
Let us know how it does.
Old Jul 17, 2014 | 08:29 PM
shawnaj7731
well Guys I got it installed (fast 102 ported) and tuned today and I was skeptical at first that it wouldn't make much of a difference over the stock peaks radical ported oem intake, also 46lb injectors where installed . The results are I picked up 21 rwhp and 9 rwtq. pretty much from 3k rpm on out to 6.5 rpm. The mid range rpm feels totally different and the car seems to run smoother and cleaner, why I don't no but it just feels totally different no bucking @ at 1300 rpms in 6th gear now also. I am a firm believer now the fast should of been done from the get go. I think it was worth the investment.
Old Jul 17, 2014 | 08:45 PM
tennblkc6's Avatar
tennblkc6
nice!
imo the ported fast is a worthy mod for the ls2...it really woke mine up.
To Fast Intake thoughts!!! please read.
