Body repairs separating panels
Old Jul 7, 2014 | 03:29 PM
WICKED Z's Avatar
WICKED Z
Default Body repairs separating panels
Whats the easiest way to separate a body panel off of inner structure . I have a wrecked panel that i need to get the old panel off of the metal stucture so i can install a new outer body panel ,. The bond ( glue is really stuck !) any tricks
Old Jul 7, 2014 | 06:30 PM
wlean99's Avatar
wlean99
St Jude Donor '14
Heat gun,pneumatic air chisel w/ flat 3" blade
Old Jul 8, 2014 | 02:12 AM
RLSebring's Avatar
RLSebring
Supporting Vendor
From: Pensacola Florida GO GATORS!!! www.rlsebring.com www.c6c7vette.com
St. Jude Donor '17
Heat gun, some shims and a 3" metal scraper.
I tap in a few shims to put pressure on the panel against the metal frame then apply a nominal amount of heat. Usually a short section of the part will pop loose from the adhesive. Work your way from front to back keeping pressure on the panel each time.
I have rebuilt a lot of cars, especially front end damage and I have found that leaving the glue on the frame acts as a perfect spacer for the new panel.
To Body repairs separating panels
