So the beauty decided to throw a little hissy fit after a dyno day.
Engine running rough and the afore mentioned codes, that refer to cylinder #7. Also getting Service Active Handling on DIC
What I have done so far: checked the plug wire, looks ok but resistance is ~770 ohms. I have a set of MSD plug wires and they measured only ~28 ohms. My thought right now is a bad plug wire. But I don't know what is normal R for stock wire. Anyone know? Plus I'm thinking of just swapping out the MSD's with the stock wires. I mean 28 vs 770 has got to be better. Right? At least in the electrical world.
I did pull the plug and I think it looked ok. 15k miles on a NGK TR7ix.
I pulled the codes with my Inovo Scan tool but could not clear them. Is this something I have to pull a battery cable for 5-10 min, to clear?
Kelly
