Gear Oil
Old Jul 18, 2014 | 10:30 AM
jimy's Avatar
jimy
Default Gear Oil
I'm going to change the gear oil in my 2007 Base M6. Some people say you must use Dextron 75w-90. Is that a must or a recommendation? What are other options?
Old Jul 18, 2014 | 11:23 AM
MachineSilver05C6's Avatar
MachineSilver05C6
I used Amsoil Severe Gear and a tube of Slip Lock. Ive had no issues. I bought their hand pump which made filling the diff easy.
http://www.amsoil.com/shop/by-produc...e-gear-75w-90/
http://www.amsoil.com/shop/by-produc...-oil-additive/
http://www.amsoil.com/shop/by-produc...tle-hand-pump/
Old Jul 18, 2014 | 12:33 PM
mfoti's Avatar
mfoti
Good Advice. This swap cured my rear end clunking problem when the GM fluid did not.
Old Jul 18, 2014 | 01:20 PM
SUB VETTE's Avatar
SUB VETTE
SUBVETTE
The Dextron oil is GM recommended and contains a limited slip friction modifier to prevent limited slip clutch sticking which is the clunking frequently complained about. After experimenting with several oil and additive combinations to cure this problem, GM finally settled on this Dextron oil with additive and put out a technical Service Bulletin to implement the procedure at its dealers. When I changed over to the Dextron it cured all previous clunking my 06 had previously displayed since new. I have been happy ever since. It sure worked for me.
Old Jul 18, 2014 | 10:37 PM
cclive's Avatar
cclive
Me too, "Dexron LS".
To Gear Oil
