LS7 oil pressure sensor replacement tips
Old Jul 19, 2014 | 03:46 PM
NitrousMan's Avatar
NitrousMan
Default LS7 oil pressure sensor replacement tips
Hey guys,
My oil pressure gauge has been pegged at 130psi for a week and the motor runs fine so it looks like the sensor needs to be replaced. Is there anyway around having to pull the intake on an LS7 to change it? There's no coolant in the intake so do I need to drain the system? Thanks for any tips.
Old Jul 19, 2014 | 07:02 PM
haljensen's Avatar
haljensen
No need to drain the cooling system even though the manual for my '05 said to do so.
It's a pretty easy job, with even a little mechanical experince you'll do fine.
