2011 GS won't unlock
Old Aug 11, 2014 | 04:27 PM
riverrat68's Avatar
riverrat68
Default 2011 GS won't unlock
Has sat for a couple of days, now fobs won't work, key in rear won't work, can't open anything to get to battery. What to do?
Old Aug 11, 2014 | 04:30 PM
RicK T's Avatar
RicK T
Can you explain why the key won't work in the rear lock?
Can you turn it at all? Can you turn it a full 90 degrees? It doesn't fit the lock?
Old Aug 11, 2014 | 05:23 PM
cclive's Avatar
cclive
The metal key fits in a simple lock that pulls a cable to open the trunk....what is it about that that is not working?
Old Aug 11, 2014 | 06:25 PM
Homer3D's Avatar
Homer3D
The key/lock to open the trunk is mechanical and should work regardless if the car or fob has power. If you aren’t able to open the trunk with the key, something else is wrong.
Old Aug 11, 2014 | 07:02 PM
haljensen's Avatar
haljensen
Sounds like a dead battery as to why it won't unlock. Have no idea why the key won't work, it has nothing to do with the electrics on the car, are you turning the key a full turn till it stops?
If the battery is dead and your key won't work in the hatch then you'll have to get a locksmith to wedge the window open and reach in with a hook to the release lever on the floor, then you can open the hood and change the battery.
Old Aug 11, 2014 | 08:46 PM
Bill Dearborn's Avatar
Bill Dearborn
If the key isn't turning you may have dirt in the lock. There is a lot of highway grit that gets sucked onto the back of the car and it does get into the lock. Try spraying some WD40 in the lock cylinder to see if you can free it up.
Bill
Old Aug 12, 2014 | 09:44 AM
riverrat68's Avatar
riverrat68
I had the passenger window down about 1.5 inches. Bent a coat hanger and pulled the release. Battery was dead. Rolled it out of the driveway(figuring I could call a tow truck if I could not fire it up) , and fired it in reverse.
Thanks for all your help. Oh, have NO idea why the key would not work, but will find out today.
Riverratt
Old Aug 12, 2014 | 01:57 PM
cclive's Avatar
cclive
The metal key is now a priority for you....be sure to let us know what you find...
To 2011 GS won't unlock
