P0700 & p0894
After I got it installed and tuned my tuner told me it seemed like my tranny fluid was low.
I drove it for a few days and it was slipping a lot and coming out of gear going into 3rd on the few WOT attempts I tried.
So I took it to a transmission shop and they told me it was about 2 quarts low and they filled it up. And that the fluid that came out when they pulled the drain plug looked clean and they didn't see any debris.
So after that it drove great and shifted perfect when doing pulls.
Until about the last week or so. Whenever I would do a hard pull from about 55-60mph it would shift past it's shift points like it was having trouble shifting .
Most of my driving is around town or on the freeway for a few minutes.
Until today, I had to drive about an hour on the freeway and if I would give it a little bit of gas "traction control active" would pop up.
Then on my way back home the check engine light came on and I pulled into an advanced auto parts and borrowed their code reader and got the codes P0700 and P0894 .
Any ideas on what could be the problem would be great.
You mentioned your "tuner". Did he tune the TCM?
Possible causes
- Low transmission fluid level
- Dirty or contaminated fluid
- Internal transmission failure
Help with Possible causes What does this mean?
When is the code detected?
When the Powertrain Control Module (PCM) detects excessive Torque Converter Clutch (TCC) slip when the TCC should be engage, then the trouble code P0894 is set.
P0894 Chevrolet Description
The Powertrain Control Module (PCM) monitors the difference between engine speed and transmission output speed. In D3 drive range with Torque Converter Clutch (TCC) engaged, the engine speed should closely match the transmission output speed. In D4 drive range, with the TCC engaged, the TCC slip speed should be -20 to +50 RPM.
I guess I should give him a call tomorrow and tell him what codes I'm getting .
