Help! Removing Center Air Dam
Old Aug 21, 2014 | 05:48 PM
bartsky's Avatar
bartsky
Default Help! Removing Center Air Dam
I have the 2 outer pieces off, and the three 10mm bolts out of the front center piece. I took out two 7mm bolts out as well. How do I get the center piece out from this point?? Thanks....
Old Aug 21, 2014 | 07:01 PM
bartsky's Avatar
bartsky
Got it off!! It was those last two push pins you cannot see until you pull bumper down a bit. Now getting new one in may be a different story...
Old Aug 21, 2014 | 07:03 PM
timd38's Avatar
timd38
Great!
Old Aug 24, 2014 | 02:48 PM
bartsky's Avatar
bartsky
Got it back on!! What a PITA!! I did this laying on the ground. If you have a lift, that's the way to replace air dam...
To Help! Removing Center Air Dam
