Does anyone know if an LS6 batwing pan will fit an LS2/3?
Thanks!
It will fit, but you will have to either use a Mast Stroker windage tray, use your existing tray, or shim the LS6 tray. You will also need the LS6 pickup tube and dip stick. The oil filter is also different from the LS2 & 3.
