Best C6 Brake Upgrade WITHOUT Changing Wheels?
Old Sep 23, 2014 | 12:55 PM
rnbiker's Avatar
rnbiker
Originally Posted by timd38
Lots of choices and opinions!
Brother.... You said a MOUTHFUL....lol..... Decisions, decisions!!
Old Sep 23, 2014 | 01:28 PM
elite38's Avatar
elite38
I'm no expert but wouldn't zo6 brakes fit since you already have zo6 wheels? Is there anything else different?
Old Sep 23, 2014 | 05:00 PM
Guard Dad's Avatar
Guard Dad
I'd go with the Z06/Grand Sport brakes or aftermarket equivalent, this is a fast car so put some real brakes on it. They will get the job done and look good doing it.
All the comments about pads and temperature ranges and what is most cost effective are all valid but his car packs some serious power and I have never regretted having too much braking capability.
Old Sep 23, 2014 | 08:07 PM
timd38's Avatar
timd38
Those brakes require different wheels, plus they will turn to junk after a good track day. If you do a track day and drive the car like you stole it, the pins will stick and other issues. If all you want is looks, they are great brakes.
StopTec, Wilwood, AP, Baer are all better alternatives. Dave Hill was pissed at Brembo about something so he killed Brembos when the car launched. Dave Hill also did not want steering wheel controls, so as soon as he retired, the car got steering wheel controls. Yes one person does have that much influence.
Old Aug 30, 2021 | 09:29 AM
???'s Avatar
Originally Posted by rnbiker
My car is NOT a Z51...just base all around except for the rear widebody and the Z06 stock rims. From what I am gathering.... It would seem that I can leave my front end body stuff alone and I think I am planning to change out my Z06 stock front rims for some replicas that match but are stock base front width (someone had mentioned the fronts were the same regarding clearance..yes, same diameter, but 1" wider than base and different offset). I was only considering using the Z06 front wheels (and corresponding widebody front) to accommodate Z06 brakes..but it sounds like I can get significantly better braking without going too crazy overboard. Lots of excellent ideas on here to work with. Fluid is a little dark, so I am going to start with fluid, pads and lines...then consider some drilled or slotted rotors if I don't see enough of a difference. I loved the advice on the track and I will have to see what is around me for options on a long straight to test my braking both before and after. Any additional opinions are welcome as well... Cheers...
no one ever follows up on these threads. replying to see if the email sent out brings people back to tell what they went with and did it work.
