2007 corvette a6
Old Sep 19, 2014 | 11:57 AM
clayz's Avatar
clayz
Default 2007 corvette a6
Ok h/c/I stock bottom end ls2
Checked reluctor wheel its ok
checked voltage to crank sensor its ok
changed crank sensor just because
Ok my problem is car starts runs fine when driving
once you cut it off for bout lets say 3to5 minutes car starts
back up but it has no rpms its misfiring real bad and its throws
a crank sensor code
My question is could it be out off timing .
Old Sep 19, 2014 | 02:21 PM
clayz's Avatar
clayz
Bump
Old Sep 19, 2014 | 03:34 PM
SoloJ|BU11ET's Avatar
SoloJ|BU11ET
I had a similar problem on my 2006 . I had the warranty luckily but they ended up replacing my crank shaft position sensor and the heads as well. I haven't had any problems since then . I hope that's not the case with you man .
Old Sep 19, 2014 | 03:42 PM
clayz's Avatar
clayz
Thanks man preciate you chiming in but I changed the crank sensor and the heads i been running for years lol tfs 225 . But i had a timing chain failure recently and i put all
New parts In plus I had to valves changed in the heads iono hope it aint the heads geesh
To 2007 corvette a6
