Replace stock radio with stock nav unit
Old Sep 22, 2014 | 10:55 PM
rmiller86's Avatar
rmiller86
Default Replace stock radio with stock nav unit
I have a 05 coupe with stock radio, 6 disc changer,*XM*radio, Bose system, no onstar. I want to replace the stock unit with a stock nav unit. Anyone know if this woild be possible with the component I have installed? Will the GPS use the XM*antenna*or will I need a seperate antenna? I also would assume the wiring would just plug into the nav unit, I hope. Any help or suggestions, or other sites to check out would be appreciated. Thanks!
Old Sep 22, 2014 | 11:32 PM
CDN-VETT's Avatar
CDN-VETT
I have a 05 vert installed kenwood dnx680hd needed gm multi wire kit, gm ant adapt kit no new antenna works fantastic installed front and rear camera nav is GARMIN very happy with it 14 months
Old Sep 22, 2014 | 11:41 PM
rmiller86's Avatar
rmiller86
Thanks! I will check that out.
Old Sep 23, 2014 | 10:16 PM
Dano523's Avatar
Dano523
Your bose system already has the VSS harness (taped back to the large radio harness)..
If you have on-star, then you already have the factory mic. If not, the wire is there, but will need to cut the hole to install the factory mic.
One in the plastic bottom left.
You will need a factory nav antenna, but they are only around $50, and it gets mounted to the same position using the same factory tabs (above the center ducts to the left,and one of the tabs you are just going to use a zip tie to secure it to that tab, instead of the pins that comes with the Nav antenna that would require the dash to be pulled instead).
The only last thing will be if you are buying a used OEM nav unit. It will need to be security cleared so it can marry to your car (Dealer will charge around $100 to use a Tech II to clear the used NAV unit so it will marry to your car once you have it mounted in the car)
Old Sep 24, 2014 | 07:56 AM
timd38's Avatar
timd38
Id you call Dennis at Double D, they will sell you a plug and play aftermarket unit that looks factory.
Old Sep 24, 2014 | 08:17 AM
1bdvet's Avatar
1bdvet
U.S. Air Force
St. Jude Donor '05 thru '26
I have 05, and replaced with Kenwood radio with all the bells and whistle except for the GPS cause it easy to update the maps just plug it into computer.
Here's all options I have, and they all work great.
Old Sep 24, 2014 | 02:45 PM
Buddy A's Avatar
Buddy A
The big advantage to an OEN nav is HUD works with the nav. I have an OEM nav out of my 08. It's collecting dust.
Old Sep 24, 2014 | 02:51 PM
QKSLVRZ's Avatar
QKSLVRZ
I really haven't used the Nav on my 13, but the UI/map compared to the Factory Garmin in my 13 Durango sux's!
Old Sep 24, 2014 | 06:46 PM
rmiller86's Avatar
rmiller86
Does no good collecting dust. Do you want to get rid of it and clear some shelf space?
Old Sep 24, 2014 | 07:30 PM
Buddy A's Avatar
Buddy A
like you said, does no good collecting dust. Yes
Old Oct 21, 2014 | 04:06 PM
rmiller86's Avatar
rmiller86
Does your car have bluetooth and steering wheel controls?
Old Oct 21, 2014 | 04:18 PM
rmiller86's Avatar
rmiller86
Why would I need a factory mic? Not sure how the system works I guess.
Old Oct 21, 2014 | 04:25 PM
timd38's Avatar
timd38
If you call Dennis at Doubled, he will send you an aftermarket unit, plug and play.
To Replace stock radio with stock nav unit
