2008 6l80 trans has problem. code p0700
Old Sep 26, 2014 | 09:52 PM
hnaskoct's Avatar
hnaskoct
Default 2008 6l80 trans has problem. code p0700
That's the only code it throwing the car cranks up put in gear and pulls off the completely stops pulling ..when i put it in park then go back to drive it won't move at all...I have to cut car off for few secs then crank back up hurry and throw it in gear the it pulls off slow then stops pulling again..van someone help, is it maybe a bad solenoids or is the trans straight is slipping..I might be in denial but u know these trans can do sum weird things sometimes..thanks
Old Sep 26, 2014 | 10:01 PM
RicK T's Avatar
RicK T
There has to be at least one other code. The P0700 is only the code that is requested by the TCM when something else is wrong. THe P0700 is to set the MIL (malfunction light).
It's probably something not too serious but I suggest you stop trying to drive it until you figure it out.
Old Sep 26, 2014 | 11:25 PM
hnaskoct's Avatar
hnaskoct
Rite I kept tryin to move it so I can get another code but that's the only code it's throwing and I just noticed that if the trans is cold it goes in reverse, and drive fine..As it gets hot the more it messes up until it completely stops and does what I mentioned above
To 2008 6l80 trans has problem. code p0700
