Engine Running Lean, P0171 and p0174 codes
Car is a bone stock 2007 manual trans, 33K miles.
After driving the car long enough to get thoroughly warmed up, this usually takes about 20 – 30 minutes and oil temps approaching 100*C/212*F, it starts losing power under full throttle . First it’s only in the higher revs, around 5,000 RPM, and the engine will pull hard to that point then stop revving as though it has hit a rev limiter. Then as the engine continues to warm and the heat soaks into everything, it starts losing power at increasing lower revs and starts to hesitate and stumble under load. Initially, no DIC messages, no CEL or other lights come on. All gauges normal. The car continues to run fine and rev freely under light to moderate throttle, as though nothing is wrong, but will choke every time under heavy load. The first time it happened on a Sunday afternoon, I was an hour from home, and continued to drive it to get home. After about 45 minutes, the CEL came on, and the codes were p0171 and p0174, lean condition bank 1 and bank 2.
I then took it to my dealer and they diagnosed a vacuum leak at the intake manifold, and replaced the gasket. They claim that upon inspection the gasket showed deterioration. However, the problem persists. I have discussed the situation with the dealer, and they are puzzled, they were certain they had it licked. I have an appointment to meet with the SA and the service manager next week to discuss what diagnoses were already performed, and what further diagnosis they would do going forward, and we’ll see where that leads. In the past they have been good to work with, we’ll see how this goes. I do not want the m working on my car unless I have confidence that they can fix the problem without open-ended trial-and-error parts replacement. The car is drivable so long as I stay under half throttle and, since the dealer cleared the codes, they have not returned.
Just wondering if anyone knows what the problem might be, or anything particular I should try to help diagnose the issue. Any suggestions are appreciated. Thanks in advance.
EDIT/UPDATE: see post 6, looks like fuel pump is shot.
good luck
Tom
Lean= too much air,,,,,, or not enough fuel,
On My tow rig we would get P0171 on a hot engine,heavy towing load in the hot afternoons on Highway5. Changed the front O2 sensors and reset codes. Next race tow, same thing again, P0171 left bank lean. finally heard the pump fuel on a cold start and it sounded slow and different. Replaced the pump , no more lean codes. the " tea bag filter" on the pump inlet was plugged big time ( 95000 miles )
Just sayin,,,,Racer86
I ended up purchasing a Redline smoke tester to check for any intake/exhaust leaks. Obviously I didn't have any.
It is also possible that you could have a rolled injector o-ring.
Both the pump and filter are inside the tank, going to be a little pricy to drop the tanks, so hopefully thats not the issue. I will ask the dealer first, since they were so confident about the manifold gasket, to confirm that they put everything back together correctly. If they did, then I'll see what they say about the charges for the gasket re & re, and what they recommend next and specifically what fuel system diagnostics will they do and at what price. Fortunately, even though this is frustrating, the car is still drivable so long as I don't romp on it so I have time to ask questions and hopefully get it fixed and keep the dealer honest.
Dealer hooked up their live diagnostics gear and determined loss of fuel pressure, they claim the fuel pump is shot. The tech could not explain to me how that would be temperature related, and progressively worsen as the car gets heat soaked, however the dealer has agreed that if they replace the pump and the problem, as shown on their diagnostics, remains, they will refund the full shot. They will also credit the half the labour for the manifold gasket replacement towards the fuel pump, even though they insist the manifold had a leak and needed to be replaced.
I am awaiting the price for the pump re & re, the tech says be ready for close to $2K all in. Does that sound right?
I guess things just wear out, either with time or mileage, but I am a bit concerned that if you've done everything right by the car, why an eight year old fuel pump would go bad with low miles.
One question on your first post: you say it's a 2007, bone stock, and it's been running fine for three years--what happened to/in the other years before the last three years?
* Might be more. Saw prior posts w. $2500+ USD.
I bought the car as a used, one-owner garage queen with 6K miles on it. It was also originally sold and serviced by this same dealer.
