Differential Gurus....
Old Oct 11, 2014 | 05:34 AM
dev1360's Avatar
dev1360
Default Differential Gurus....
Opened up my 2009 3.42 diff to start the rebuild.
I had ordered the Z06 pinion carrier, and Z06 shafts with gear.
My diff already has those parts. Is this normal?
Old Oct 11, 2014 | 09:38 AM
Boomer111's Avatar
Boomer111
I did not think so.
Old Oct 11, 2014 | 04:49 PM
Boomer111's Avatar
Boomer111
And I thought that the GS models contained this upgrade mentioned.
Again walking out on a limb.
Old Oct 11, 2014 | 04:53 PM
MARSC6's Avatar
MARSC6
If they are the same I would assume they are supposed to be shared parts.
The shaft pictured from what I can see looks the same as what I removed from my 06. What is supposed to be upgraded on the z06 shafts?
Old Oct 11, 2014 | 05:16 PM
dev1360's Avatar
dev1360
I had seen a few posts in passing in long lost threads that alluded to 09+ diffs having upgraded parts.
But I, along with many others are told that we need to pay and upgrade our diffs to Z06 stuff. Well, I already have it, and proof is in the pics.
Old Oct 11, 2014 | 05:19 PM
dev1360's Avatar
dev1360
It's hard to say, most of the shaft info comes from the C5 world. C5s had one piece short shaft and gear with a hollow section. There isn't much info out there from C6 guys.
I'm hoping to find some concrete info from some of our diff builders.
Old Oct 11, 2014 | 05:44 PM
dev1360's Avatar
dev1360
GS' have a full Z differential. 9" ring gear, case, etc.
Old Oct 11, 2014 | 05:57 PM
MARSC6's Avatar
MARSC6
The gear and short shaft were 2 separate pieces in my diff. This was from a 06 manual base model.
Old Oct 12, 2014 | 12:56 AM
Dano523's Avatar
Dano523
06 to 08 uses the two piece shaft,
It was the 05 that has the weaker one piece shaft instead (shown on top).
Old Oct 21, 2014 | 06:35 AM
dev1360's Avatar
dev1360
Clutches from an 06 automatic differential and the clutches that came out of my 09 differential.
My 09 diff had carbon clutches already.
Old Oct 21, 2014 | 09:09 AM
Josh@SpartanLSX's Avatar
0Josh@SpartanLSX
Former Vendor
Yes it's normal. All the 09+ cars we've done that I have in recent memory all had the upgraded parts from the factory and carbon clutches.
Old Oct 21, 2014 | 07:07 PM
dev1360's Avatar
dev1360
Thank you for the answer.
Old Oct 21, 2014 | 10:54 PM
0Josh@SpartanLSX
Former Vendor
You're very welcome.
To Differential Gurus....
