FAIL Comp cams trunion upgrade
Ran 24 Hours of Daytona on stock LS2 rocker arms
Banner Racing GXP.R with Katech engine
The entire PC class in the Tudor series with Katech engines
Runs 24 Hours of Daytona on stock LS3 rocker arms (with aftermarket cam)
Several SCCA Trans Am 2 teams with Katech engines
Runs entire TA2 season on stock LS3 rocker arms
GM Racing SCCA World Challenge V1 Cadillac CTS-V.R with Katech engines.
Stock LS2 rocker arms
GM Racing SCCA World Challenge V2 Cadillac CTS-V.R with Katech engines
Stock LS3 rocker arms
Never a failure.
Never a failure.
Having choice is wonderful! And I do appreciate the smooth sounding idle away from the OEM rocker's sewing machine ticks.
Without the excessive floppy runouts, probably ended up with less friction and heat!?
Comp Cams - $129
There are thousands of people using these with no issues. With that said, there have been many reported cases of galling of the trunion shaft. Unfortunately this doesn’t become evident until the bearing is removed from the trunion for inspection. I did not find any cases where this galling led to a catastrophic failure of the component. In several cases the bearing would spin freely but once disassembled the shaft was damage similar to the ones pictured in the OP. There have also been reported failures of snap rings breaking, which may or may not be the result of installation error.
Brian Tooley Racing - $115
From Brian Tooley’s post on tech almost a year ago regarding the difference between their product and Comp Cams:
While similar in basic design there are some key differences that justify the price difference. First, Harland Sharp cross drills their trunions to provide access for splash oil to get to the bearings. Second, the Harland Sharp trunions include hardened washers between the c-clips and the rocker. Lastly, the materials used are more suitable for this application.
I found this info from two posts on tech that has some very good info on the differences between Harland Sharp and the rest:
There are plenty of unhappy people on here that have had the Comp kits fail, the early Harland Sharp kits also failed but I believe they had surface heat treated shafts also.”
“You are relying on a thin layer of hardened steel supported by a soft inside & 8620 that is typically used is not a good choice, the 52100 that Harland Sharp uses is a full heat treated steel used in some bearing applications.
And for everyone's information I am a tool & die maker @ the former GM owned former New Departure/AC Delco Chassis/Delphi bearing plant which made/makes bearings on all your vehicles so I know a little about bearings.”
CHE - $420
CHE offers a unique solution as they do not rely on a bearing but rather utilize a bushing. This is regarded by many as to be the ultimate solution to the problem. I have not found or heard of any reported failures with the CHE product. Of course that comes at a price.
In that oil report - http://speedtalk.com/forum/viewtopic.php?t=30483
It lists Mobil 1 as very solid product. It's all I ever ran in my race engines, always saw most consistent oil pressure and bearing/cylinder life.
For what it's worth, GM recommends it as well
Comp Cams - $129
CHE - $420
One major component removed, to have better durability on the CHE is that, they don't ship their bushing as a kit. Bushing is only done in house.
Few other notables:
"C" clip retention is effective as long as it is not over stretched during R&R.
Skewed bearing installed will result is early failures and galled shaft, which serves as the inner race.
Racing cars in order to stay competitive, engines need rebuilds. Loads of OEM parts are used but basically, consumables.
On the other hand, DD can enjoy a relative trouble free life with selected components, installed properly to enhance its longevity.
Thanks everyone for some very good posts backed up by great information. I realized I could have just replaced them but I really wanted to try and figure this out. Maybe it will work for others.
Thanks VictorF for that post. I didnt know harland sharp already had it figured out. I will inspect again in another 6k (or before if the magnet is fuzzy)
Kits can be used with OEM bolt and/or aftermarket bolt or stud.
I bought a set Friday and installed them today. Nice to have an option for a easy DIY bushing kit and not having to send them in. Affordable as well.
Attachment 48363347
Attachment 48363348
Attachment 48363349
This is an honest question not trying to be a smart aleck, I've seen no need to "upgrade" but if there was a compelling reason, I would. My car sits a fair amount now so if there's something to be done better for cars that aren't daily driven, I'd be interested in that.
So far, all I've seen is failures from this "upgrade"...
The bushing kits offer peace of mind to the guy/gal that has modified their engine.
