Advice on tapping threads into the subframe
Old Oct 15, 2014 | 08:45 AM
el es tu's Avatar
el es tu
Default Advice on tapping threads into the subframe
I need to tap a couple of 1/4"x20 thread holes in the subframe to mount a diffuser. The issue I see is trying to get the holes straight into the frame while drilling from under the car. Are there any tools that could be used to help keep the thing straight?
Im considering making a guide out of aluminum stock for this purpose...
Thanks!
Old Oct 15, 2014 | 06:29 PM
MARSC6's Avatar
MARSC6
Trying to rig up a guide sounds like more trouble then its worth. Llift the car enough so you are able to drill straight. Just make sure you have decent drill bits so they don't walk around.
