Tfs 255
Old Oct 23, 2014 | 11:28 AM
Pmarine1's Avatar
Pmarine1
Default Tfs 255
First of the car is an 06 C6 6 speed with a 402, ported 243's, comp Lsr 235/251 .621/.624 on a 115, fast 92 and 1 7/8 headers and put down 506 to the wheels. I have a set of TFS 255's and an intake sitting on a shelf, do you guys think I will gain enough to warrant putting them on?
Old Oct 23, 2014 | 04:57 PM
Neumonic2002's Avatar
Neumonic2002
St. Jude Donor '09-'10
What intake is it that is sitting on the shelf?
Old Oct 23, 2014 | 05:04 PM
Pmarine1's Avatar
Pmarine1
Stock LS3, heard not much to be gained by switching to FAST but I could be wrong
Old Oct 30, 2014 | 08:08 AM
Pmarine1's Avatar
Pmarine1
Anyone?
Old Oct 30, 2014 | 08:16 AM
timd38's Avatar
timd38
I would do it. Rectangular port heads tend to flow better.
Old Oct 30, 2014 | 05:15 PM
C U IN REARVEIW's Avatar
C U IN REARVEIW
But......heard that cathedral port heads maintain/gain more low/mid range power.
Old Oct 30, 2014 | 05:17 PM
Pmarine1's Avatar
Pmarine1
I guess I can't find any real comparisons on these heads so I may have to be the test mule
Old Oct 30, 2014 | 11:56 PM
Patrick G's Avatar
Patrick G
You should be able to gain a solid 40rwhp with the Trick Flow heads if you have them milled to the same chamber size as your ported 243 heads. Don't want to lose compression. My Trick Flow 255 LS3 heads flowed 391cfm at .650" straight out of the box. Most 243 heads flow below 320. With a cam that small, you will have ample low rpm torque with the 255 Trick Flows.
Old Oct 31, 2014 | 09:45 PM
Pmarine1's Avatar
Pmarine1
Thanks Pat, if I plan on supercharging I should leave them alone right?
Old Nov 1, 2014 | 10:18 AM
Patrick G's Avatar
Patrick G
Yes, don't mill the TFS 255 LS3 heads if you plan on running a supercharger.
To Tfs 255
