help with c6 Power steering pressure hose
Old Oct 28, 2014 | 06:39 AM
ramstar27's Avatar
ramstar27
2nd Gear
Default help with c6 Power steering pressure hose
Hi to all, I am new to this forum and recently purchased an 05 c6. I got it for a great price and has a few upgrades that save me money and time since they are already there. Anyway, I was curious if anyone has had to replace the power steering pressure hose on any c6 yet? that was one issue the car has. I cant even see the hose/ leak. I was hoping someone may be able to walk me thru the steps they took to get to it and replace it. I def see the alt has to come out. Thanks
Old Oct 28, 2014 | 07:29 PM
truckplay's Avatar
truckplay
TAKE PICTURES FIRST. the hoses should be an assembly including the cooler. the lines at the rack are different sizes. just pay attention to the routing.
Old Oct 28, 2014 | 07:44 PM
timd38's Avatar
timd38
I received a recall notice for my 06. The hose on your car is about 18". The replacement hose is about 36". The routing is far more complex on the replacement.
I installed a Turn1 pump and Aeroquip Teflon, steel braided line because I did not like the complexity of the replacement hoe.
timd38's Avatar
timd38
The pressure side does not go through the cooler, the return side does.
Old Oct 29, 2014 | 07:17 PM
ramstar27's Avatar
ramstar27
2nd Gear
yes i believe it is the pressure line. It appears to be under the alternator. Do any of you guys know if there is a micro fiche that shows how to get to it? and thank you for the info so far.
Old Nov 9, 2014 | 07:19 PM
05C6GAC's Avatar
05C6GAC
With the replacement hose being so longer than the original does any one have the suggested routing with hopefully pictures???
To help with c6 Power steering pressure hose
