C5 vs C6 4L60e differences
Old Oct 29, 2014 | 02:19 PM
JackLS1R1's Avatar
JackLS1R1
Default C5 vs C6 4L60e differences
Does anybody know the EXACT differences between a C5 Corvette and 2005 C6 Corvette 4L60e transmission?
Old Oct 29, 2014 | 05:01 PM
RicK T's Avatar
RicK T
This was, might still be, on the Museum website 10 years ago:
Durable 4L65-E delivers automatic performance
The available automatic transmission in the C6 is the new Hydra-Matic 4L65-E four-speed. An upgraded version of the C5’s 4L60-E, the “L65” is strengthened and revised to accommodate the LS2’s 400 lb.-ft. of torque.
To beef up the internals, a five-pinion planetary gear set was added – replacing a four-pinion gear set. The extra gear reduces friction and loads carried by all the gears. The washers between the gear sets are made from Teflon, allowing optimal operation at high speed.
For protection from the high temperatures that are generated by high speed, a four-plate oil cooler has been added. When the transmission fluid reaches 127 degrees Celsius (approximately 260 F), the torque converter lock does not disengage, except briefly during shifts. This prevents fluid shear in the torque converter from adding heat to the transmission.
The 4L65-E uses a highly advanced electronic controller that has been specifically calibrated for Performance Algorithm Shifting. This technology automatically selects the optimal gear for a given driving condition, making it a willing accomplice for performance driving and hard cornering. The 4L65-E transmission shifts at higher rpm, compared to the C5’s 4L60-E, to take advantage of the LS2’s higher horsepower and rev range.
Old Oct 30, 2014 | 01:07 PM
Shane@RPMtransmissions's Avatar
0Shane@RPMtransmissions
Former Vendor
Nothing is the same on them except for some of the cases.
Old Oct 31, 2014 | 04:48 AM
AR_Kong's Avatar
AR_Kong
Would a c5 converter fit a c6 4l65e?
Old Oct 31, 2014 | 08:36 AM
Former Vendor
No bolt pattern, converter height and input shaft are all different 05 is a 2005 only transmission
To C5 vs C6 4L60e differences
