Header install question
Old Nov 3, 2014 | 05:05 PM
nick814's Avatar
nick814
Default Header install question
I have a 2008 c6. I installed Lg superpro headers, cat delete, and x pipe. Didn't have time to finish installing slp axle backs but wanted to go for a spin. I'm getting a lot of sputtering and lag when I go wot until the rpms are higher... Is this due to not having mufflers on or what?
Old Nov 3, 2014 | 07:46 PM
MachineSilver05C6's Avatar
MachineSilver05C6
Assuming all spark plugged wires are connected tight, my guess is with the headers the knock sensor is probably pulling timing thinking there is a knock. Mine was doing the same until it was tuned. Get a tune and go have fun!
Old Nov 4, 2014 | 07:03 AM
Seadawg's Avatar
Seadawg
It could be running way lean too. I would not play with it too much until I either got a tune, or some way to monitor the AFR while running with only the headers and X pipe...
Old Nov 4, 2014 | 10:02 AM
haljensen's Avatar
haljensen
Missing axleback shouldn't cause a miss.
The most likely thing is a spark plug/coil wire is loose. It'll run terrible at slow speed but almost normal at high RPM.
Old Nov 4, 2014 | 03:18 PM
nick814's Avatar
nick814
Thanks for the input guys. Aside from making sure all of the connections are tight, is there anyway to test/verify that the connections are good afterwards?
Old Nov 4, 2014 | 04:03 PM
nick814's Avatar
nick814
It was a loose plug wire. She is running like a champ now. Thanks again for the help.
To Header install question
