Drag pack tire sizes
Old Nov 4, 2014 | 01:51 PM
live4toys's Avatar
live4toys
Default Drag pack tire sizes
I'm going to be running 17x4 front and 15x10.5 rear RTS wheels on my Grand Sport. What tire sizes are guys running on this set up?
Old Nov 4, 2014 | 08:01 PM
HOXXOH's Avatar
HOXXOH
4.5/26.0x17 M&H's are on my fronts. Can't help you on rears.
Old Nov 5, 2014 | 04:32 AM
C6David's Avatar
C6David
Another front option are the m&h 185/55/17
Old Nov 5, 2014 | 06:30 AM
live4toys's Avatar
live4toys
Thanks guys. Those are the two I was looking at for the front. Really I'm just not sure if I should go with 26" or 28" tires for the rear. Going to need to hook up 900-1000 hp.
Old Nov 5, 2014 | 07:58 AM
turboed's Avatar
turboed
28" for that much hp is what i would go with.
Old Nov 5, 2014 | 08:58 AM
BIGMAC's Avatar
BIGMAC
I am led to believe a 28" tall rear tire will set off the AH/TC nannies and render the GS useless (and possibly dangerous).
I have a 2012 A6 GS nearing completion (ECS w/ meth, 2600 stall, 3.42 Z06 rear, 700+ RWHP) and I am still trying to find a wheel/tire combo that will not set off the AH/TC demons due to front/rear tire diameter greater than tolerated by the computer. I would like to go with a 17" rear rim to avoid going to dropped spindles. Vengance Racing sells a GS/Z06 Weld Package with a 185/50/18 M&H front (25.2 tall) and a 325/45/17 M&H rear (28.5) tall, but that combo has a 13% diameter difference. I have been trying without success to find out the maximum % the computer will allow; I received some info 4-5% is it.
Any guidance will be appreciated.
Old Nov 5, 2014 | 09:28 AM
realcanuk's Avatar
realcanuk
St. Jude Donor '13
That M&H tire actually measures to 27.2 inches when on the car. I run them with PSS 225/45/18 and have no issues with nannies. I don't have my notes as I'm away at SEMA and forget the exact height of the fronts. You could look it up and if you can find something about the same height you won't have issues.
To end up safe what I did is figure out the exact difference of the stock tire hieghts and stick to something with a similar difference.
Old Nov 5, 2014 | 09:49 AM
HOXXOH's Avatar
HOXXOH
Assuming you will not be using those wheels/tires on the street, you won't have enough time or distance on them at the track for the nannies to cause problems due to size differences. The nannies reset themselves every time you shut down, which is why you have to push the TC button to deactivate them each startup.
Old Nov 5, 2014 | 10:00 AM
BIGMAC's Avatar
BIGMAC
Thanks. I am surprised the M&H tires measure only 27.2" on the car. I got the 28.5 from a tire size calculator and the M&H website lists the tire at 28.
The stock dimensions are 25.6/26.7=4.3%. I have a 345/30/19 NT05R on the car (27.3=6%) now with no problems. If the M&H are 27.2 as you report they are the same as the Nittos and should be OK.
Old Nov 5, 2014 | 10:06 AM
BIGMAC's Avatar
BIGMAC
Thanks for the info. There has been a lot of conflicting information on this subject out there as well as the impact of running low tire pressure with the TPMS in place (computer goes crazy and limits speed to 55 mph). I would like to run with TC off and AH on. The car will see almost all dragstrip time and be trailered to/from the track.
Old Nov 5, 2014 | 08:41 PM
HOXXOH's Avatar
HOXXOH
I run with TC off and AH on and no TPMS. Never a problem at the track from the nannies that wasn't warranted.
The AH saved my butt one time when I hit a water spot near the finish line from the guy before me that blew a radiator hose. It was a night session and not visible. Suddenly getting crooked at 120 is not fun. My reaction time was a lot slower than AH.
Old Nov 6, 2014 | 10:17 AM
Anthony @ LGMotorsports's Avatar
0Anthony @ LGMotorsports
Former Vendor
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13
Get a hold of Mark.
He can get you setup with wheels/tires/spindles and the whole works for the car if you are wanting to do something like that.
https://carlyleracing.com/
He has been a dealer of ours for a long time and runs the LG Drag spindles on his car.
Old Nov 6, 2014 | 04:15 PM
Unreal's Avatar
Unreal
28s will work fine. I drove for the past 3 weeks on my 325/50/15s, no issues. Just have to get close to the same front size. When I had a 25.6" front I would get some engine drag warnings, but went to a 26.8" front and no issues.
Old Nov 6, 2014 | 05:11 PM
WHY TRY?'s Avatar
WHY TRY?
Will an M&H 325/45-17 be good choice for street tire for roll racing? 610 N/A and 730+ on spray
Old Nov 6, 2014 | 05:14 PM
Unreal's Avatar
Unreal
Yes, that is decent for a 17". A 15" would be a lot better.
315 MTs are also a good choice, or wait for all the new MT tires coming out soon.
Old Nov 6, 2014 | 05:16 PM
WHY TRY?'s Avatar
WHY TRY?
I wasn't aware of all new MT's. What's suppose to be better and improved about them?
Old Nov 6, 2014 | 05:41 PM
atomicfusion's Avatar
atomicfusion
Give me a ring if you have questions... I have these packages all figured out.
To Drag pack tire sizes
Old Nov 6, 2014 | 06:03 PM
Unreal's Avatar
Unreal
Everything.
Old Nov 6, 2014 | 06:05 PM
WHY TRY?'s Avatar
WHY TRY?
Everything.
I should've said which tire? ET Streets, ET Drags?
Old Nov 6, 2014 | 09:24 PM
Unreal's Avatar
Unreal
They have 3 new tires coming out. ET Street R, Et Street SS, and a Pro bracket tire.
