When does the throttle body become relevant???
Old Nov 24, 2014 | 12:12 AM
SlowBusa08's Avatar
SlowBusa08
Default When does the throttle body become relevant???
Like the title says, when does the stock ls7 throttle body become the choke point?
If a HCI LS7 car has all the standard bolt ons, when is it necessary to upgrade to a 102mm?
I'm debating between rolling with the factory TB, or upgrading to a NW102 while everything is getting tuned. I'm planning on running E85, if that matters.
Old Nov 24, 2014 | 12:48 AM
TTZ06VETTE's Avatar
TTZ06VETTE
I'm running the stock TB with twin turbo 850RWHP and a sheet metal intake and it works fine. Can always have it ported and polished.
Old Nov 24, 2014 | 12:50 AM
White_Lightning's Avatar
White_Lightning
1300 rwhp here... stock tb... i think it helps more on pd blowers that have to pull the air through the tb..
Old Nov 24, 2014 | 01:29 PM
SlowBusa08's Avatar
SlowBusa08
Whitey, are you NA or forced? I know on a boosted vehicle the TB makes even less of a difference.
I'm really curious if where the data is that shows when the stocker becomes a choke point, or how much more could you gain with the aftermarket TB's everything else being equal. So same car, same dyno, tuned for stock throttle body, then swap the TB and adjust the tune, what kind of real world numbers would be seen.
Not really sure I'm asking this the right way...
Old Nov 24, 2014 | 01:42 PM
timd38's Avatar
timd38
I did Nick Williams only because I like the look. Not because I needed it......
Old Nov 24, 2014 | 09:24 PM
SlowBusa08's Avatar
SlowBusa08
well I hate money just as much as the next guy, but I'm not sure even I could justify replacing it for the hell of it. I can live with the stockers appearance.
Old Nov 28, 2014 | 01:24 PM
SlowBusa08's Avatar
SlowBusa08
Any other comments? I'm a little surprised there aren't more people weighing in on this.
Old Nov 28, 2014 | 08:37 PM
cpweisbrod94's Avatar
cpweisbrod94
I'm curious as to what the gains of a ported TB are over a aftermarket NW unit.
Old Dec 4, 2014 | 04:52 PM
hrt vlv's Avatar
hrt vlv
Whoa all the guys have some awesome performance cars!They got to be scary fast.So my knowledge is small. On a car that is a daily driver can you go to big, maybe losing bottom end? drive ability? And if I did a t/b should I just get a upgraded intake? No headers at this point.
Old Dec 4, 2014 | 07:34 PM
Dano523's Avatar
Dano523
If you are stock, or close to it, the the TB is not your choke point, its the production flaws in the intake manifold, the rough channels in the cast heads, and the stock exhaust manifolds.
The stock manifold can be ported to clean up the production flows on the cheap,
regarding porting head, almost cheaper to just go with CNC heads,
And as for the The exhaust manifolds, LT headers with high flow cats solves that problem.
To When does the throttle body become relevant???
