wheel straightening
Old Nov 30, 2014 | 12:21 PM
JaimeVrod's Avatar
JaimeVrod
Default wheel straightening
Does anyone know a good shop that can straighten an out of round 19" C6 5 spoke wheel, preferably in the Chicago area?
The wheel is out of round on the rear face. There is no sharp bend in the perimeter, the rear face is just somewhat oblong. Measuring in one direction compared to the other direction (90 degrees apart) shows a difference of about 1/4-3/8".
The front face is true.
Old Nov 30, 2014 | 02:19 PM
gbrtng's Avatar
gbrtng
in Elk Grove Village:
http://www.wheelsamerica.com/Wheels-...-Locations.php
The San Antonio guys refinished a couple of my aluminum wheels - looked better than original. I can only assume they can straighten a wheel too ...
Old Nov 30, 2014 | 04:34 PM
Marina Blue's Avatar
Marina Blue
Default Wheel Collision Center in Bath, PA
This shop has a patented method of straightening wheels. When done, the wheels are perfect and just as strong as new. Very few, if any, other shops can do this. Much of their business is out-of-state mail ins. Check them out here and give them a call: http://www.wheelcollision.com/
Old Nov 30, 2014 | 09:40 PM
Gearhead Jim's Avatar
Gearhead Jim
St. Jude Donor '13
GM's position is that aluminum wheels can be refinished, but not straightened.
Their attitude is that if it's bent, replace it.
That may be unreasonable, but...
I was able to buy two sets of 2009 painted split spoke wheels for our car, in like-new condition, for $300/set on Craigslist; about three years ago. Local sellers, I inspected in person, paid cash, threw 'em in the trunk of our beater and drove home. Total time about 2 hrs/set, not counting some waiting for the desired wheels to show up on Craigslist. Chicago area.
If your wheel is the standard painted one, you might be able to buy a good used one cheaper than having yours straightened.
Old Nov 30, 2014 | 11:00 PM
AORoads's Avatar
AORoads
St. Jude Donor '15
"In honor of jpee"
Very interesting factoid, Jim. I didn't know that but then, it does make some sense. Steel wheels would be a different story tho, of course.
Old Dec 1, 2014 | 12:36 PM
Gearhead Jim
St. Jude Donor '13
GM is full of lawyers, so I don't know what the standards really should be.
I've heard of aluminum wheels that were straightened and then failed, sometimes soon and sometimes much later. That's bad.
But we all know people who had aluminum wheels straightened and lived happily ever after. I suspect the secret is partly in evaluating whether the wheel can indeed be straightened safely, and partly in using the right technique. Whether a particular wheel service is good at doing both of those things, could be hard to tell.
Old Dec 1, 2014 | 09:06 PM
Bill Dearborn's Avatar
Bill Dearborn
A number of dealers send bent wheels out to be repaired. My wife bent two wheels on our Malibu when she hit a pot hole. The dealer said they had a guy that came to the shop every friday and he would repair them. What they will not repair is a wheel that is bent around the hub area so that it has an excessive amount of run out. In other words one that wobbles when spun. The wheel repair guys won't touch them.
Bill
Old Dec 2, 2014 | 04:11 PM
JaimeVrod's Avatar
JaimeVrod
Thank you Gbrtng. Wheels America is taking care of this for me. Next day service. You got to like that.
Old Dec 2, 2014 | 10:29 PM
Gearhead Jim
St. Jude Donor '13
Please let us know how you like their work after reinstalling.
Thanks.
Old Dec 3, 2014 | 10:29 AM
JaimeVrod's Avatar
JaimeVrod
Thanks.
I picked up the wheel and at first appearance all looked good. The dent was no longer plainly visible. Upon closer examination, I'm not sure that it was repaired as well as it should have been. On the rear face, the diameter varies from 20 9/16" to 20 3/4". The front face has uniform diameter all the way around.
I was planning to use these rims for R compound track tires. Now I'm not sure this wheel was repaired to the extent that it will be safe and that tread wear would be uniform (excluding uneven outside to inside wear from track use). Does anyone have any insight if this variation in diameter is normal?
Old Dec 3, 2014 | 12:54 PM
gbrtng's Avatar
gbrtng
Mount the wheel on the vehicle and gauge the barrel runout instead of the outer rim. Take it back if the barrel isn't within a few thousandths and have them try again.
Old Dec 5, 2014 | 05:45 PM
cclive's Avatar
cclive
Due to the properties of aluminum, it's just not something that I would do. Once aluminum has passed its' yield strength, (in other words, bent permanently) it will not be as strong as it was before if it is bent back into shape. Bending a wheel back to shape is completely different than refinishing a ding or scrape. Those wheels are very inexpensive to buy used, why not do that?
Old Dec 8, 2014 | 07:46 PM
Gearhead Jim
St. Jude Donor '13
cclive and I think alike.
Old Dec 8, 2014 | 10:04 PM
JaimeVrod's Avatar
JaimeVrod
Well the shop I took the wheel to, Wheels America, didn't do such a good job. I'm going to take it back to them to see if they can do better. If they can't, I'll be looking for 1 polished aluminum 5 spoke rear wheel (19x10). If you have one in very good condition, let me know.
To wheel straightening
