Minimum Rotor Thickness on 2011 GS
https://www.corvetteforum.com/forums...on-the-c6.html
Looks like the service manual says the minimum serviceable thickness for rotors is:
Fronts - 30.3 mm 1.19 inches
Rears - 24.5 mm .965 inches
Thanks to BEZ06
Very easy to turn drilled or slotted rotors.
You just can't take that deep of cuts that you would with a solid rotor, and since the cuts will be interrupted cuts over the slots/ drilled holes, you have to make sure that you have the damper belt around the out side of the rotor so you don't end up with a lot of chatter in the facing cut.
As for the problem with the Vet rotors, from brand new, there is just not that much extra metal on the rotor to allow for deeper turning and still be in the min thickness range. Gm did this to prevent extra spun weight with the rotor being too thick; and that they get to sell more rotors since they can not be turned as much/as deep.
So on that note, figure that you get turn the rotors once to clean them up if they are not too bad, but if you have deep gouging, your SOL thinking that you had a great deal of extra thickness of metal on the rotors to turn them down a few times. Really, if you can put a quarter up against the outer lip on the rotor, and the lip is higher that the quarter (or groove that deep that you are trying to clean up with turning), time for new rotors since they will end up way past the min allowed by the time the rotor is turned.
If your rotors are just above the minimum thickness, can you safely install new pads and go full life on the pads? As the brakes wear, the rotors will get below the minimum spec long before the new pads are worn out. Maybe GM accounts for that in the minimum spec, but somehow I doubt it.
Two things you have to look at in regards if the rotors can be turned or not (had enough meat left on it).
Take a good look at the rotor, and notice that the outer edge of the rotor has worn more than the inner hub side surface. This is the reason that you have to mic across the entire area of the rotor to get the min thickness of any part of the rotor to determine if it machinable or not.
Take a look at the outer edge, and notice that the lip if you placed a quarter on the surface would not be proud of that lip.
This rotor still has enough meat in it (if it has not been turned before) to be turned to square the entire surface of the rotor flush and square to itself.
I bring this up, since if you just shove new pads on this rotor, pad break in is going to be a PITA/longer event, since the faces of the rotors are not square across the entire surfaces, and it will take a longer time for the pads to wear to this angle to correctly mate as well.
Also to add, when you do pull the rotors to have them turned (even if lightly surfaced to clean/entire surface square them up), you can get to the E brake shoe star nut to reset the E brake when doing the brake job.
Last time I looked in the Service Manual, it said not to turn the rotors unless they are seriously grooved or pitted.
Some people say you should do a very light cut when changing to a different type of pad, that might be true. Or not.
BTW, does anyone have an answer to the question I asked in post #6?
Seating and cable stretch.
As for seeing how bad this is on a car, just pull the E brake, and it should fully engage the brakes with the handle about half way up. If the handle is going all the way up and hitting the stop before the E brakes engage firmly, then time to adjust the E brake shoes via the star adjuster.
Short version, choke the front tires, loosen the lug nuts on the rear tires, get the back end up on either a lift or jack stands, pull the calipers off (the large bolts only if you have base/z51 and your leaving the brackets still on the caliper when you pull them) and zip tie them up so they are not hanging from the brake lines (throw a block of wood between the pads in case someone steps on the brakes), then starting on once side, turn the rotor by hand while listening for any E brake rub with the handle all the way down.
Now pull the rotor, and start adjusting the E brake out via the star adjuster until when you put the rotor back on and turn it, you hear just a slight rub in one spot of the rotor being turned. Now get in the car, pull the E brake to center the E brake shoe on the rotor disc area, put the handle back down, and go back and rotate the rotor again. If you still have a slight contact of the E brake pad to the rotor drum area, back off the star a click or two until the E brake shoe not longer makes contact to the drum part of the disc (may need to pull the E brake again to recenter the shoe on the drum).
One side completed, and now do the other side.
When you put the calipers back on, clean all the Blue loctite off the large Bolts, reapply Blue 242 loctite to them (heavy side), and torque the bolts to 125ftlbs.
Note, depending the amount of brake fluid in the tank, may need to pull some of it out (wall paper syringe from any hardware store will work). The reason for this, you will need to slightly compress the pads/pistons back into the calipers so the brake pads clear the rotor when you remove the calipers, and this will force fluid back into the tank (read so you don't end up with the fluid overflowing from the tank, since it will strip paint very, very quickly from any painted surface).
Note, sure that GM included a safety margin of error in regards to min rotor thickness before replacement, but if you are going to be pushing the brakes hard, better to use GM min thickness safety error margins.
The rotors will have some embed on the them from the old pads, so if nothing else if switching to another type of pad, good to remove that before bedding in new brake pads.
As for turning or not, mic the rotor from the inside hub side to the outer edge side, and see how uneven the wear is to the over all rotor surfaces. There are times that the surface looks fine, but the rotors are no longer parallel/square across the surfaces to each other (outer edge has a lot more wear to the rotor than the inner hub side surface).
Again, take a look of the rotor from the other thread that I posted, and would dare to guess mic'g the rotor both sides, almost a hundred thousands difference from out edge contract area both sides, to inner hub contact both sides. Now translate this to new pads trying to mate up with the off square surfaces of the rotors to each sides (both, how the pads need to wear to mate up to the rotor canted surfaces, and the cocking of the pads in the caliper as they are trying to wear to match these canted surface planes as well.
Note, too bad the op did not show the old pads in his right up on the other post, since you would have been able to see the un-evern wear of the old pads to begin with; and the fact that the new pads will first have to wear to this canted edge to just mate up to the rotor, and since the brakes favor outer surface wear, by the time the new pads wear get half lifed, will be even a worse cant of brake pad wear.
Bluntly, the rotors can be turned, and if nothing else in regards to a light pass, to just parallel the both sides of the rotor contact surfaces to each other once again before you do mate in new pads to them. Plus on the back rotors, great time to knock off the edge lip of the drum section so you can reset the E brake without having to fight that lip to adjust the E brake shoe/pull-reinstall the rotor back on while adjusting them.
On the front, $15 each is about right since they only have to take slower passes on the rotors them selves, while on the backs, around $20 each, since not only rotor surfaces, but the you want them take a light pass on the E brake drum surface to remove the outer lip that forms as well.
E brake drum on the rear rotor, and although this one is rusted, the drum has min wear since there is no lip on the E drum.
Good luck with your's; my '12 GS with 46K would still roll with the E-Brake totally on, so I took it into the dealer (still under warranty). They had to order parts (two weeks or so) before it could be fixed. Now it you use a lot of beef on the handle, the car will stay put.....but you have to pull up so hard I know my wife couldn't do it. Now you know why the C7's have gone to an electric activated (button) E-Brake
