Air Bag wiring
Old Dec 4, 2014 | 11:30 AM
onelesshat's Avatar
onelesshat
Cruising
Default Air Bag wiring
Hello all,
I recently had to replace my radiator (radiatior support vs steep driveway). While doing so I accidentally pulled the wires from the driver side airbag sensor. Could someone tell me, or take a pic of the way the 2 wires go back into the plug. One is yellow, and I believe the other is black.
Will correctly replacing the wires get my airbag light off, or will I have to have that reset?
2006 Z51
Old Dec 4, 2014 | 04:59 PM
Pixlix's Avatar
Pixlix
Yes once the vehicle starts it checks to make sure that all the components are present and if nothing is missing you should be good, only time you need a reset it when a component is activated during a crash or something
Old Dec 4, 2014 | 05:00 PM
Pixlix's Avatar
Pixlix
You might want to disconnect your battery cable tho just to reset but I doubt it it's needed
Old Dec 5, 2014 | 11:21 AM
cclive's Avatar
cclive
Also, it may take a few start/run cycles for the system to cancel the light, so don't panic if it doesn't happen immediately. The computer wants to confirm that it is not an intermittent fault.
To Air Bag wiring
