2009 issues?
Old Dec 12, 2014 | 07:58 PM
happiedazs's Avatar
happiedazs
Default 2009 issues?
I currently own a 2003 Vert and looking at a 2009 Vert.
Are there any electrical or mechanical issues with the 2009 Verts and have there been any recalls that I should be aware of?
Old Dec 12, 2014 | 08:40 PM
zumatodd's Avatar
zumatodd
Original owner:
EVAP Vent Solenoid B/O- replaced (Code PO449) (Replaced Pigtail Harness with updated connector also at this time) (20,000 miles/Sept. '14)
Master Cylinder Leak- replaced along with Brake Booster (17,500 miles/Feb. '14)
Normal annual maintenance
Just did tires also in Sept. '14
No recalls...
Old Dec 13, 2014 | 08:30 AM
dev1360's Avatar
dev1360
No issues with my 09.
Old Dec 14, 2014 | 02:00 PM
rado63's Avatar
rado63
Stock shifter on a Manual trans was loose and tightened and repaired. Rear axle nuts were replaced and torqued. Front rubber trim around wind screen was replaced all under warranty. a check on the web site https://recalls.gm.com/#/ can look up the vin#. At this time the website does list my 2009 vin as part of the recall for the low beam jumper wire needed to prevent loss of low beam headlamps.
To 2009 issues?
