Valve ?
Old Jan 4, 2015 | 08:18 PM
Realfast86's Avatar
Realfast86
Default Valve ?
For giggles i decided to put a magnet on the valves in my Mast 305 heads which are supposed to have Hollow SS intake and Inconel exhaust. The intake surface and stem is magnetic and the exhaust face is non-magnetic but the stem is does that sound right?
Old Jan 4, 2015 | 08:23 PM
timd38's Avatar
timd38
If you look at the transition area between the stem and the head, you can sometimes see how the head and stem are fused together.
Old Jan 4, 2015 | 08:33 PM
Realfast86's Avatar
Realfast86
The heads are assembled so i cant see that area i'm more concerned about the intakes even being Hollow SS the faces should not be magnetic correct?
Old Jan 5, 2015 | 01:23 AM
jeb6754's Avatar
jeb6754
A lot of the stainless steel types have iron in them. You should alway check stainless with a magnet because they can rust with the iron in them. Just a thought.
Old Jan 5, 2015 | 08:04 AM
Realfast86's Avatar
Realfast86
These are supposed to be Mast hollow stem SS valves but a magnet sticks to them good whats that tell me?
Old Jan 6, 2015 | 02:38 PM
irok's Avatar
irok
that premium alloy stainless is magnetic
Old Jan 7, 2015 | 02:02 AM
Guard Dad's Avatar
Guard Dad
I'm not a machinist but I do know that some grades of stainless are magnetic. It was a surprise to me when I first learned about it but it is true.
Old Jan 7, 2015 | 11:18 AM
HOXXOH's Avatar
HOXXOH
Pure metals are rarely found in any product manufactured today because they don't have the characteristics needed to match the design purpose.
Using a magnet is only helpful to identify some iron alloys.
Old Jan 8, 2015 | 10:55 PM
C6z06man's Avatar
C6z06man
Like said before. Certain SS has traces of iron and can feel a magnet pull against it.
Old Jan 9, 2015 | 09:52 AM
haljensen's Avatar
haljensen
No such thing as "some iron in SS". Stainless steel IS IRON alloyed with carbon.!
All steel is iron with added carbon. SS is iron + carbon + chromium + nickel.
ie; 18/8 SS is iron + carbon + 18% Chromium + 8% Nickel
Old Jan 10, 2015 | 11:21 AM
The Clevite Kid's Avatar
The Clevite Kid
St. Jude 15 Year Donor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15-'16,'17,'18-'19-'20-'21-'22
Default SS Lesson
18/8 (aka 304 or 300 series) stainless steel - with about 70% iron - is non-magnetic because the nickel makes the atomic structure face-centered cubic, like copper, silver, and gold.
400 series stainless steel has at least 12% Chromium to make it very rust resistant - and about 85% iron - but no nickel, so the atomic structure is body-centered cubic, just like plain old mild steel, and it IS very magnetic.
High quality knife blades are made from 440C (in the 400 series) stainless steel that can be heat-treated to a high strength and hardness, and is also quite magnetic.
I have a P.E. license in metallurgical engineering, among other things.
To Valve ?
