Please help, separating diff from trans
Old Jan 6, 2015 | 01:55 PM
dentalfloss's Avatar
dentalfloss
Default Please help, separating diff from trans
Hello. I am in the process of installing a new clutch and upgrading my differential. At this point I have removed the rear suspension subframe and have the diff/trans/tube still attached and lowered. I removed the 4 bolts from the diff to trans and the diff will not separate from the trans. I tried prying from all different angles but it will not separate. I must be doing something wrong. Thank you in advance
Old Jan 6, 2015 | 02:05 PM
MARSC6's Avatar
MARSC6
Since your installing a clutch just take the torque tube, trans, and diff out together then separate when off the car. The diff will slide right off if you have all the bolts out.
Old Jan 6, 2015 | 03:18 PM
subfloor@centurytrans's Avatar
Supporting Vendor
2024 C6 of the Year Finalist - Modified
2020 Corvette of the Year Finalist (track prepared)
2019 C6 of Year Winner (track prepared)
I usually work with automatics, but on my car there's another bolt on the lower driver's side that needs to be removed. All the other ones require a 13mm socket but this one is bigger (although I can't remember exactly what size it is).
Old Jan 6, 2015 | 03:22 PM
Supporting Vendor
Found a picture:
Old Jan 6, 2015 | 05:15 PM
dentalfloss
Default thank you
Originally Posted by subfloor@centurytrans
Found a picture:
Thank you but I do not have that bolt. I took some pictures and will post them in the morning. I have researched this to death and can not figure out why they will not separate. Since I have it in the position it is in, why not separate the diff now as I can not see how taking them down together will help in separating them.
Old Jan 6, 2015 | 10:47 PM
c5racr1's Avatar
c5racr1
I would leave the trans and diff together and take the trans lose from the TT. But since u don't want to do that, use a pry bar. Remember u have to be weight neutral or the output shaft from the trans won't let it go. Hope u drained the fluid in both or you will have a serious mess on your hands. I remember 2 bolts at the bottom that had to be removed with a box end wrench also
Old Jan 8, 2015 | 04:08 PM
5 Liter Eater's Avatar
5 Liter Eater
St. Jude Donor '11
Is this an '05 you're working on? If so there is a stud on the diff with a nut on it that faces the front of the car. Its on the bottom in a little cutout so it's easy to miss. But I agree, if you're just installing a new clutch there is no need to separate the TT/trans/diff.
Old Jan 8, 2015 | 04:46 PM
timd38's Avatar
timd38
Profile says 05.
Old Jan 8, 2015 | 04:56 PM
5 Liter Eater
St. Jude Donor '11
Then it's that stud fo' sho'.
Old Jan 8, 2015 | 05:00 PM
5 Liter Eater
St. Jude Donor '11
I had it a bit wrong though. It's a rearward facing bolt that goes through a hole in the middle on the bottom of the diff. Seen below.
Old Jan 8, 2015 | 07:36 PM
dentalfloss
Thank you everybody for your help. Yes you are correct there was a fifth stud with a nut hidden on the bottom of the diff. I removed it and the diff came loose. You really have to look close as it is hidden. I am now good to go. Again thank you.
To Please help, separating diff from trans
