Dislodging an axle...tips?
Old Jan 7, 2015 | 10:11 PM
trayack's Avatar
trayack
Default Dislodging an axle...tips?
Trying to change out a leaky axle seal on my cars C6Z with DSS monster axles. Everything is apart now but for the life of me I can't separate the DSS axle from the rears stub axle. Tried a pry back ext but it won't budge.
I could always undo the allen head bolts holding that flange on and use a puller to get the flange off but I'm really tryng to avoid that.
Anyone got any tips?
- Travis
Old Jan 8, 2015 | 08:18 AM
ErnieN85's Avatar
ErnieN85
- Travis
yes there is a tool for that it is a slide hammer and a big fork that slips (with difficulty) behind the inner joint. I got the setup on ebay
OTC tools
Old Jan 8, 2015 | 10:36 AM
etaylor14's Avatar
etaylor14
I changed my left rear axle 2 days ago without much difficulty. I watched a u tube video on how to change a rear wheel bearing to get a idea of how to do it. I just put the axle nut flush with the end of the shaft and whacked it with a hammer a few times to remove it from the bearing. After you get it out of the bearing just pull a few times to free it from the rear end.
Old Jan 8, 2015 | 03:03 PM
trayack's Avatar
trayack
I got it, thank guys.
- Travis
Old Jan 8, 2015 | 10:44 PM
C6z06man's Avatar
C6z06man
Hammers and pry bars. Only tools you need. Lol. Good luck.
To Dislodging an axle...tips?
