Starter gear sticking
Old Jan 11, 2015 | 07:10 PM
68birdls1's Avatar
68birdls1
Default Starter gear sticking
Hey guys, another issue I'm running into on the swap. Ls7 engine, t56 magnum with the fbody bell housing. I'm running the new camaro style starter with the plug for the signal wire to spin.
When I bump the key, the engine will start to turn but then you just hear that starter spinning. The gear gets stuck in the flywheel but comes right out when I turn the engine over with a ratchet.
I've attached a pic of the starter from the top view. The gap gets wider as it goes down. The gap on the bottom side of the starter is even across.
I have no clue, I thought I remembered that you don't shim ls1 style starters. Any advice is always welcome. Thanks for looking.
Daniel
Old Jan 11, 2015 | 07:27 PM
timd38's Avatar
timd38
What flywheel did you use?
Old Jan 11, 2015 | 08:30 PM
68birdls1's Avatar
68birdls1
The clutch kit was from mantic.. The er2
Old Jan 12, 2015 | 08:06 AM
timd38's Avatar
timd38
My bet, based on the limited info, is that the starter and the flywheel are not working together. I would call Mantic and tell then what starter you have.
To Starter gear sticking
