LS2 Intake VS Fast Intake.
Old Nov 14, 2011 | 07:32 PM
Gering's Avatar
Gering
Tolero Apto Victum
Default LS2 Intake VS Fast Intake.
Hay guys, I just picked up my new in the box Fast Intake today and needed to get it installed and dyno tuned. Luckily Geoff Cope at LMR "Late Model Racecraft" was able to help me out. They are located at 11755 West Little York Rd. STE 106, Houston, TX 77041 (713) 466-9900. http://latemodelracecraft.com/
The dyno pic below is a base line pull before the install of the Fast intake and my final pull with the Fast intake manifold installed.
The overall numbers are as follows:
RWHP increase by 28.29 hp.
RWTQ increase by 27.07 tq.
I do have a mild heads and cam setup. Also there is more info in my profile.
I would like to thank LMR and corvette forum member FloydSummerOf68, who helped me decide on this upgrade.
Old Nov 14, 2011 | 07:57 PM
Neumonic2002's Avatar
Neumonic2002
St. Jude Donor '09-'10
Great results!
Old Nov 14, 2011 | 08:02 PM
LS1LT1's Avatar
LS1LT1
Nice gains!
Old Nov 14, 2011 | 08:24 PM
timd38's Avatar
timd38
nice! A friend of mine at GM tells me that a fast on an LS2 makes a big difference, but not on an LS3 and this verifies it!
Old Nov 14, 2011 | 08:39 PM
theVcar's Avatar
theVcar
St. Jude Donor '08
Originally Posted by LS1LT1
Nice gains!
Hey, do you really think those are good numbers for all those mods?. if I only add a cam to my bolt ons i would prob be at 460rwp
Old Nov 14, 2011 | 08:43 PM
jrstang473's Avatar
jrstang473
From His Profile
Year & Model
07 Z51 A6
Color
Black
Mods
Suspension: LG Motorsports Lowering Bolt Kit, GM T1 Sway Bars with Poly Bushings, GM T1 End Links, LG Sport Shocks.
Drivetrain: RPM A6 Differential - 2.56.
Braking: Performance AFX Motorsports Two Piece Slotted Rotors, Stainless Steel Brake Lines, Motul RBF 600.
Cam: (220/224, .581/.581, 113 LSA)
Biography
Engine: Callaway Honker Air Intake, Ported Throttle Body, Livernois Motorsports CNC Ported Stage 3 Heads, Katech Billet Belt Tensioner, Katech Coil Relocation Kit, Katech Cast Aluminum Valve Covers with Valve Cover Insert, 160 Degree Thermostat, ATI Super Harmonic Damper, FAST Precision Flow Fuel Injectors 33 LB/HR, Brisk Spark Plugs, MSD Spark Plug Wires, CompCams Custom Camshaft, Roller Lifters, Pushrods, Kooks Headers, Corsa High Flow Cats, Crossover Pipe, Sport Exhaust & Tune.
That is allot of money spent on the car , something seems off.
Old Nov 14, 2011 | 08:45 PM
Joe_G's Avatar
Joe_G
St. Jude Donor '08
Well...to be precise, this verifies half of that theory! It doesn's speak to the ls3 side of the coin.
OP I found the track gains to be higher than the dyno gains would indicate...the FAST is a GREAT mod for the ls2.
That car of yours is really rich...you'd get more power if you leaned it some, FYI. I personally run 12.5 and some guys go up to 12.9. But rich is safe, particularly if you are a road course maven.
Old Nov 14, 2011 | 09:14 PM
FloydSummerOf68's Avatar
FloydSummerOf68
Huge gains...excellent
I bet it feels GREAT from about 40-70 now. That's where I felt a huge surge in the powerband.
Old Nov 14, 2011 | 09:17 PM
FloydSummerOf68
Originally Posted by jrstang473
From His Profile
Year & Model
07 Z51 A6
Color
Black
Mods
Biography
Nothing seems "off"
He lists that the cam he's running is a 220/224 and the tune is obviously on the safe/rich side. I mean look, it's only running probably 11.0-11.5:1
A larger cam would net another 30-35rwhp with those heads, lean it out a bit and put him at an easy 460-470rwhp through an auto tranny.
All seems about right to me, but yes, it's a VERY mild build with that cam.
Old Nov 14, 2011 | 09:52 PM
taken19's Avatar
taken19
Track Junky
Great results! Dollar for dollar, one of the best mods for an LS2.
Old Nov 14, 2011 | 10:22 PM
vetteownr85's Avatar
vetteownr85
Great Gains!!
Old Nov 14, 2011 | 11:26 PM
LS1LT1's Avatar
LS1LT1
Well yeah, the peak numbers might appear a little light but I was merely commenting on his gains from the FAST intake, they are in line with what other internally modded LS2s have gotten and the results were quite strong.
Old Nov 15, 2011 | 07:45 AM
jpuli28's Avatar
jpuli28
Was your OEM manifold ported or stock? How much of a diff between a heavily ported (formato stage 2) OEM manifold and a Fast?
Old Nov 15, 2011 | 07:48 AM
jpuli28's Avatar
jpuli28
$900 + then install $ for 28 hp? I'm happy for the OP though.
Old Nov 15, 2011 | 07:52 AM
FloydSummerOf68
Install takes ~1 hour
Yes, for the cost, it's one of the best mods for the LS2. I mean, look at the huge torque increase across the entire powerband.
Old Nov 15, 2011 | 08:52 AM
musicman2's Avatar
musicman2
Default Fast
HEY GERING--------THANKS for your post----that sure answers allot questions !! Your cam & build is almost identical of my 07--same before figures with my A6------I sent you a PM---Would be interesting to post this same set-up with a Peak Speed ported TB & Stock LS2 intake--anybody done that ???
Old Nov 15, 2011 | 09:02 AM
Gering's Avatar
Gering
Tolero Apto Victum
Sir, a while back I was told that maybe my stage 3 heads was a little to big for my mild cam. So maybe the stage 3 heads reduces the velocity, which in turn reduces my over all HP. I am not an engineer, so do not flame me to much.
To LS2 Intake VS Fast Intake.
Old Nov 15, 2011 | 09:06 AM
Gering's Avatar
Gering
Tolero Apto Victum
Thanks for the info! I do not drag race, but love to cruze the back roads. My 07 has about 124,XXX miles on it.
Old Nov 15, 2011 | 09:10 AM
Gering's Avatar
Gering
Tolero Apto Victum
The increase in HP/TQ is noticeable, also the increased throttle response is very nice.
Old Nov 15, 2011 | 09:17 AM
Gering's Avatar
Gering
Tolero Apto Victum
Sir, my stock manifold was not ported and the fast manifold also was not ported.
