That website is a great tip. Thank you for sharing it.
One of my big pet peeves is making changes to a car without adhering to OEM standards, ie, adding ballast resistors to exterior LED lighting. I absolutely hate those cable splicers that merely cut and violate the insulation to make the connection only to have moisture corrode the wire at some later date and time. I would rather take the time to make up a weatherproof interconnect harness to preserve the integrity of the connections. Your tip looks like a good source for a lot of hard to find electrical components with which to do so.
they have access to any factory connector you want and will fabricate any harness you want with proper factory color coded wires,connectors,conduit and sleeves in any length you want
