going from FI to NA
Old Jan 17, 2015 | 11:49 AM
edge04's Avatar
edge04
Default going from FI to NA
so I am taking my previous procharged engine back to NA looking to make around 500. Car will see a lot of road course time. It is a stock ls2 bottom end with ported ls3 heads and intake, 1 7/8 LTH, just had new cam spec'd from tick.
Taking a poll on whether I should replace my head gaskets. Currently running ls9 which are .051 thick with 69 cc putting me around 10:1. Should I bother trying to raise the CP for my goals or leave it be?
Old Jan 17, 2015 | 12:12 PM
timd38's Avatar
timd38
I would ask Tick since you are already a customer of theirs.
Old Jan 17, 2015 | 01:10 PM
5knives's Avatar
5knives
Originally Posted by edge04
so I am taking my previous procharged engine back to NA...
This is unheard of.
But my initial opinion would be yes bump the CR up a little.
Old Jan 17, 2015 | 01:19 PM
edge04's Avatar
edge04
thanks, I did speak with them, now looking for 2nd opinions
Old Jan 17, 2015 | 02:01 PM
5knives's Avatar
5knives
What did they recommend?
Your current 10:1 CR is slightly lower than the stock LS2's 10.9:1. So bumping the compression back up to at least stock ratio, I'd prefer higher, would theoretically add some power and increase throttle response. But, Tick knows way more than I ever will and they're the ones working on your car, so.....
Old Jan 17, 2015 | 03:03 PM
edge04's Avatar
edge04
I too would like to see higher as well but not sure what the return will be. Not much more work as motor is ripped apart now and gaskets are cheap
Old Jan 17, 2015 | 07:11 PM
dennis50nj's Avatar
dennis50nj
I am making close to 500rw with an automatic 373 gears with the 243 heads ported milled and serdi valve job on the factory valves and fast 90, a stick and ls3 heads should do it easily
To going from FI to NA
