djrueth
Old Feb 11, 2015 | 08:00 PM
djrueth's Avatar
djrueth
Cruising
Default djrueth
TJ, in Nov of 2012 with 41700 miles on my stock 2006 Vette the left axle broke. Last week at 51900 the right axle broke. The car is not a daily drive nor do I smoke the tires. Axles should not brake. Your thought on axles braking
Old Feb 11, 2015 | 08:08 PM
RicK T's Avatar
RicK T
Where, what part of the shaft, did each axle break?
Old Feb 11, 2015 | 10:38 PM
djrueth's Avatar
djrueth
Cruising
The axle split.
Old Feb 11, 2015 | 10:39 PM
djrueth's Avatar
djrueth
Cruising
The axle split in two.
djrueth's Avatar
djrueth
Cruising
The axle split in two...........
Old Feb 11, 2015 | 10:40 PM
djrueth's Avatar
djrueth
Cruising
The axle split in two..................
Old Feb 11, 2015 | 10:43 PM
ky-ss's Avatar
ky-ss
so basically the axle split in two?
Old Feb 12, 2015 | 06:19 AM
djrueth's Avatar
djrueth
Cruising
Yes, that's my understanding.
Old Feb 12, 2015 | 06:45 AM
SuperchargedTundra's Avatar
SuperchargedTundra
How did the axle break?
Old Feb 12, 2015 | 08:36 AM
djrueth's Avatar
djrueth
Cruising
Both axles broke under the same conditions. I took off from a stop at about 1/4 throttle had a little chirp from the tires and then bang.
Old Feb 12, 2015 | 09:12 AM
AORoads's Avatar
AORoads
St. Jude Donor '15
"In honor of jpee"
An '06 has no warranty left, and you may not be the first owner---are you? If that's the case, you probably don't know how the car was treated by the prior owner (s).
Even if you did know, or you are the original owner, things break.
Should rear axles both break at 51K miles after 9+ years of life? Maybe not. But it's mechanical, it's a car part(s) not sitting on a shelf, things break eventually. Yours was just a little bit sooner. Best explanation I can think of. Hope you get it fixed.
Old Feb 12, 2015 | 10:17 AM
MUKAK's Avatar
MUKAK
pics or it didnt happen
Old Feb 12, 2015 | 10:20 AM
djrueth's Avatar
djrueth
Cruising
Secone owner, got the car with 10k on the OD, know the first owner car was treated well.
Both axles breaking, give me a break!
Car is back on the road.
Old Feb 12, 2015 | 10:35 AM
tennblkc6's Avatar
tennblkc6
sorry to hear this and happy to hear you have her back on the road. any pics of the carnage?
Old Feb 12, 2015 | 06:47 PM
AORoads's Avatar
AORoads
St. Jude Donor '15
"In honor of jpee"
Giving you a break! It's in the rear. Glad you're back on the road.
Old Feb 12, 2015 | 11:27 PM
C6z06man's Avatar
C6z06man
So they split in 2? I wasn't sure.
Old Feb 12, 2015 | 11:33 PM
Tropicana's Avatar
Tropicana
Troll....
To djrueth
