Stalled A6 cmon in
Based on my experience, in my estimation any converter with a higher stall than say ~3200 rpm takes a bit of tuning to get the TCC lockup to work smoothly so that it feels like stock, but it is doable. I'm nearly there now.
A couple of things to remember is that with the higher 2.56 ratio, the same converter will stall higher than with a lower 3.42 and the same goes for adding FI, so you will want to factor that in.
Also bear in mind that each manufacturers advertised stall could be different and you should talk to them directly before buying a converter. In other words, one brand's 3600 could stall 4000+ rpm in your car, whereas another's might only stall 3200.
My guess would be that the best overall converter for your long term use would be something with an actual stall of around 3200 rpm. A good converter will definitely wake your car up.
Adding more pep means you must have some currently, but it's only a guess as to how much. A higher stall doesn't increase power, nor does a Z06 rear gear that you may or may not get. They both just change the power range in relationship to the car speed. Going to FI can change everything.
There are too many unknown factors to consider to even take a guess.
How about you start by mentioning how you intend to use the car and a timeline for those long term plans. These will be the same questions the installer and/or the manufacturer will, or should, ask.
All of the other brands you've mentioned have loyal customers too and I've run both Vig and Yank before with good results. To each his own.
Any given converter will stall higher in a heavier car or one with more power, particularly more low end power or one with a higher rear end gear ratio.
Therefore, if you get the stall optimised for a stock car and then add a supercharger, the same convereter will stall higher, simply because it is a fluid coupling.
The term looser comes from the feeling that you experience with a high stall converter. You have to give it more gas to move the car.
A higher stall usually provides a quicker launch, unless the converter is too loose and stalls well above your torque peak.
But there's more to consider than just off the line performance. You want a converter that gives you the best balance of performance and driveability.
The magical thing is not getting a conveter that is so loose that it becomes a nuisance to drive the car.
Think about approaching it like you would approach women, looser ones can be more fun, but do you want to live with that every day?
BTW! I'm running 9* overlap in my stock stall with the 2.73 gear. It commands my full attention on the street. :-)
