Brake Squeal
Old Feb 18, 2015 | 08:17 PM
agp45's Avatar
agp45
Default Brake Squeal
Need Help, I have a 2005 Z51 just replaced front and rear pads with GM ceramics and have a bad squeal only in reverse. Any help would be appreciated! Thanks
Old Feb 18, 2015 | 08:51 PM
RicK T's Avatar
RicK T
Did you use anti-squeal compound on the backs of the pads?
Did you install new rotors, clean or turn the old rotors or neither?
Did you follow a bedding procedure for ceramic pads?
Old Feb 18, 2015 | 09:49 PM
agp45's Avatar
agp45
I did all that you mention and had rotors turned within specs. re lubed the pins with Hi Temp loctite viper lube but still have squeal when in backing in reverse.
Old Feb 19, 2015 | 08:20 AM
Flame Red's Avatar
Flame Red
Next time, try Akebono pads. No squeals ever.
Old Feb 19, 2015 | 10:21 AM
EVRose's Avatar
EVRose
I would try a few hard stops in reverse. I have the GM ceramics on my 05 too and there are no squeals ever.
Old Feb 19, 2015 | 09:09 PM
agp45's Avatar
agp45
Thanks EV Rose I will try that!
To Brake Squeal
