Adding SWC 08' - up
Old Feb 20, 2015 | 04:25 AM
DJ_Miracle's Avatar
DJ_Miracle
Default Adding SWC 08' - up
Hi guys,
I'm finding lots of old threads about adding SWC to early cars but none about later models. The older ones are needing another coil etc.
Am I correct that a newer model doesn't need any other coil or steering wheel? Are the wires and connectors already in the harness or will it require rewiring? Is there a plug for the buttons in the steering?
Why this question: I have these volume buttons w bezel lying at home, is it worth to make them working?
Many thanks!
Daniel
Old Feb 25, 2015 | 04:18 PM
Kent1999's Avatar
Kent1999
Not quite sure where your line is on 'older vs newer', but from my limited experience and more than a few trips through the parts catalog, I think it is fairly safe to assume that if you do not have any SWC on your current car, you almost certainly do NOT have the correct clockspring to add them, regardless of year. In MY2009, SWC became standard on all models, so we are really only talking about 2007-2008 models in which the SWC were optional.
Also, the button harness inside the steering wheel (Not the clockspring - this is a separate harness) to connect to the spoke buttons is not sold separately, so the only way to get it is to find a used wheel with the harness intact, or buy a brand new wheel with the SWC controls, and it will also come with the correct steering wheel harness.
Cheers,
Kent
Old Apr 14, 2015 | 03:50 AM
DJ_Miracle's Avatar
DJ_Miracle
Hello,
"old" = LS2
"new" = LS3
Now I've mounted the buttons and noticed that I have the connectors in the wheel, but the plugs are different. So I suppose the clockspring supports SWC....
Old Apr 14, 2015 | 06:43 AM
AORoads's Avatar
AORoads
St. Jude Donor '15
"In honor of jpee"
Be advised: per the explanation by Kent, your old and new definitions won't work because '08 was an LS3 as well.
Old Apr 14, 2015 | 06:51 AM
DJ_Miracle's Avatar
DJ_Miracle
`08 for me is "new"..LS3 engine and changed interior....
To Adding SWC 08' - up
