O2 Harness Problem
Old Mar 24, 2015 | 04:47 PM
C6Steezy's Avatar
C6Steezy
Default O2 Harness Problem
I recently tried to change the front O2 sensors on my car and discovered that whoever did it last decided to cut the harness coming from the engine harness. The only plug that will separate the O2 sensor from the wiring is the one that's under the fuel rail at the top of the motor. My question is, does anyone know where I could get the missing harness sections?
Old Mar 24, 2015 | 05:12 PM
timd38's Avatar
timd38
There is a plug in the middle of the fuel rail cover that the o2 plugs into that clips into the coil holder.
So you should be able to plug a new o2 into that plug. If you have headers, you need a new o2 and an extension harness. Casper has a great selection of them.
Old Mar 24, 2015 | 05:21 PM
C6Steezy's Avatar
C6Steezy
Ok. I was unsure if the extensions would plug into that plug. Ill look into extensions. Thank you for the help.
Old Mar 24, 2015 | 06:08 PM
timd38's Avatar
timd38
Here is a variety to pick from.
http://marylandspeed.com/caspers-electronics-m-83.html
To O2 Harness Problem
