New front wheels tires - "Traction System Active" Warning
Old Mar 26, 2015 | 07:45 AM
DannyBoyC6's Avatar
DannyBoyC6
Default New front wheels tires - "Traction System Active" Warning
All, I am running slightly worn 315/30/18's on the rear and just swapped from 295/30/18's to new 275/35/18's on the front and also went with a thinner wheel up front. I had the tire shop swap TPMS from old to new wheels as well. When I got home, I had to reteach the TPMS system at each wheel as it got confused on which corner was which. I've confirmed each wheel is now accurately reading, but here's the issue:
When I go over 50mph (around 52 actually), I get "Traction System Active". Is this because of the front tire diameter being larger than the rear now? Is there anything that can be done about it? Can I use my HPTuners software to adjust it out?
I'm doing an HPDE event tomorrow and don't run with AH/TC on but am worried the system will still intervene due to confusion or something (like when running without TPMS installed).
I would have thought a search would come up with a lot of hits for this message but was surprised not to find one.
Thanks!!!!
Dan
Old Mar 26, 2015 | 08:30 AM
timd38's Avatar
timd38
If I was in Vegas, I would bet on your diagnosis.
LG in Plano, may have a fix for that. I would give them a call.
Old Mar 26, 2015 | 08:39 AM
ErnieN85's Avatar
ErnieN85
here is how to fix it for now, you can disable active handling by unpluging the steering position sensor on the steering column under the dash.
however you may not be allowed to run like that unless you are in an advanced group
phipp85's Avatar
phipp85
It will do that if you have larger fronts than rears. Are you running A6/R6? I have run the same height front and rear before and didn't have any problems.
Old Mar 26, 2015 | 08:48 AM
timd38's Avatar
timd38
Good info! How will anyone know?
Old Mar 26, 2015 | 09:53 AM
DannyBoyC6's Avatar
DannyBoyC6
I am solo so I don't have any concerns with rules but just worry about the computer freaking out like it did last year when I tried to run without TPMS installed. I'll give it a shot today to test it out and see if anything gets pissed.
Thanks for the info!!!
Old Mar 26, 2015 | 09:56 AM
DannyBoyC6's Avatar
DannyBoyC6
I'm running R888's - the fronts are 1.75mm taller based on my math plus the wear on the rears so probably more like 2mm.
Old Mar 26, 2015 | 09:58 AM
DannyBoyC6's Avatar
DannyBoyC6
Anyone know if turning off TC/AH will keep everything happy on the track despite this discrepancy in tire height? It might be my overactive brain, but I felt like the car was slowing down too fast when I let off the throttle at highway speeds testing it this morning so I was worrying about the brakes pulsing for Traction Control despite having it all turned off.
Old Mar 26, 2015 | 12:41 PM
froggy47's Avatar
froggy47
So far as I know off is off, tc/ah should not be sensing tire height (rotations) at all. That's how my c5z is, run any tire size combo you want & no intervention if it's off.
TC/AH doesn't secretly turn itself on every so often just to check & see if you have taller fronts.
Old Mar 26, 2015 | 02:02 PM
DannyBoyC6's Avatar
DannyBoyC6
Thanks for the info as always Froggy!
I've had everything freak out on track when I was having TPMS struggles so I think I'm just paranoid!
Old Mar 26, 2015 | 02:06 PM
ErnieN85's Avatar
ErnieN85
Froggy, maybe something in ABS is still monitoring wheel speeds.
depends on the code as to just what happens
Old Mar 26, 2015 | 02:26 PM
Bill Dearborn's Avatar
Bill Dearborn
As long as you have your tire pressure sensors programmed correctly and they behave while on track all you have to do is turn off TC and you will be fine. If you want to run AH it will work since AH doesn't use wheel speeds to determine when to activate. AH activates based on steering angle, lateral Gs and yaw rate.
I ran a R888 setup that had slightly larger diameter tires in front than the rear and when I backed out of the garage at the track and started moving forward TC would shut me down before the car moved 10 ft. I just pushed the button until everything was off and never gave it another thought.
Enjoy your track time.
Bill
Old Mar 26, 2015 | 02:34 PM
DannyBoyC6's Avatar
DannyBoyC6
Bill
Thanks Bill!
Old Mar 26, 2015 | 04:24 PM
froggy47's Avatar
froggy47
Battery issues will throw off all sorts of crazy codes, which is why I install a battery better than a basic lead acid battery when I need a battery. Think of the vibration & heat your battery is subject to (especially front mounted) when on track or autox.
I remember when one novice c5z guy was at my autox & had all kinds of brake issues on course. The codes made no sense, so I sent him to napa to get a new batt. Fixed everything & he bought me lunch.
Old Mar 26, 2015 | 04:27 PM
froggy47's Avatar
froggy47
I agree, of course, abs is still on unless you go to lengths to disable abs. But we're focused on tc/ah for this OP.
See post #1.
Old Mar 26, 2015 | 05:43 PM
randomus's Avatar
randomus
I totally agree with Bill, I run Nitto NT01 on my C6 (275x17/315x18) which are larger in the front than the back. Car has a fit with traction control on, it lets me know right away that its not happy. Pushing the button once will turn it off and the car drives fine. I usually hold down the button for 10 seconds to turn everything but ABS off for the track.
Bill
Old Mar 31, 2015 | 01:23 AM
Kent1999's Avatar
Kent1999
I'm interested in how ABS will NOT activate in error with such a setup (larger front tires than rear)?
ABS most certainly monitors and compares individual wheel speeds, and expects that the RPM for the front tires will be greater than the rears under normal braking due to the front's smaller diameter. If ABS sees that the fronts are turning *slower* under braking than the rears, it will reduce braking force to the front calipers to alleviate the (perceived) slippage/locking. That's how its designed to work.
I'm guessing the guys running larger fronts than rears have disabled ABS in addition to disabling AH/TC?
To New front wheels tires - "Traction System Active" Warning
Old Jun 7, 2015 | 02:44 PM
edge04's Avatar
edge04
I just installed new rims and tires and running a square set up 18x10.5 rims with 275's
and my traction system active is coming on also above 50mph.
so too be clear, shutting it off does not effect ABS? thanks
Old Jun 7, 2015 | 05:14 PM
Kent1999's Avatar
Kent1999
Technically, Shutting off TCS wil leave ABS intact -- **BUT **-- your tires being incorrectly sized *WILL* make your ABS malfunction. With your square setup, ABS will kick in prematurely or may even disable itself if it thinks there is a malfunction, since the data it is receiving from your square setup will NOT be what it sees as normal.
Both TCS and ABS depend on the correct tire diameter ratio, front-to-rear.
Old Jun 7, 2015 | 05:59 PM
DannyBoyC6's Avatar
DannyBoyC6
With TC/AH turned off at the track, I did not experience any unusual braking behavior though I don't recall ABS kicking in throughout the day. Basically, I didn't have any issues with the setup.
Dan
