Low Beam Flickers
Old Apr 8, 2015 | 07:06 PM
RaceMic's Avatar
RaceMic
Default Low Beam Flickers
My low beam passenger side headlamp is flickering annoyingly. Is this a sign of the bulb starting to fail, or some other consequential issue?
Old Apr 8, 2015 | 07:18 PM
majorpayne317641's Avatar
majorpayne317641
This is more than likely the TSB recall for the jumper wire install by the hood fuse box. You should have gotten correspondence from GM.
Old Apr 9, 2015 | 05:43 AM
Mack1919's Avatar
Mack1919
Since a possible bad connection in the fuse box would affect the low beams on both sides of the car, I'd look elsewhere first. Try looking at the lamp, ballast and connections on the passenger side of the car.
Mack
Old Apr 9, 2015 | 08:23 AM
majorpayne317641
Mack
Sorry that's incorrect the recall says it can be just one light with issues.
Old Apr 9, 2015 | 08:40 AM
Mack1919's Avatar
Mack1919
That's interesting. Is that in Recall Bulletin 13146 or another document. I'm really interested because it this changes my understanding of the problem.
Mack
Old Apr 9, 2015 | 08:46 AM
majorpayne317641
Don't remember the number but it's the most recent one. It can cause the low beams to have issues. Flickering or off and doesn't say specifically both at the same time.
Old Apr 9, 2015 | 08:53 AM
Mack1919's Avatar
Mack1919
OK. Thanks for the info. I'm getting ready to apply the recall myself on my 2013 GS and want to make sure I understand everything that's going on. Thanks again.
Mack
Old Apr 9, 2015 | 11:09 AM
RaceMic's Avatar
RaceMic
Thanks for the info. I've been sitting on the TSB (my local dealer is a PIA). I had no idea that this might be the problem. Time top suck it up and go visit the local dealer.
Edit: I found the TSB on line and it sounds like this is the exact problem. You can find the recall verbiage here:
https://www.automd.com/recall/campaign_c102754/
Old Apr 9, 2015 | 07:18 PM
wjnjr's Avatar
wjnjr
Head light recall web page:
http://www-odi.nhtsa.dot.gov/acms/cs...4V251-2256.pdf
This is the TSB with pictures and instructions for the dealer techs on how to do the repair.
Old Apr 9, 2015 | 07:31 PM
timd38's Avatar
timd38
I would recommend that you have a copy when you take it to the dealer for the recall. I had to give my local dealer the TSB number as well as the part number for the wire needed to perform the update.
Old Apr 9, 2015 | 07:33 PM
wjnjr's Avatar
wjnjr
Already done, took about 1hr
Old Apr 9, 2015 | 11:43 PM
torquetube's Avatar
torquetube
Where does it say that?
The recall is to work around a fracture-prone wire inside the UBEC (the fuse box). This wire is part of circuit no. 1970, which goes from the BCM to the coil side of the low-beam relay.
This single wire is the control signal for both headlamps.
I suppose it is conceivable that in the earliest stages of failure a very brief deactivation of both ballasts could be more noticeable on one side than the other. But in my experience, if the UBEC wire is fractured, the relay switches off when the wire expands from engine heat, and doesn't come on again until the engine cools down.
I doubt this is the cause of the OP's problem.
Old Apr 10, 2015 | 01:24 PM
cclive's Avatar
cclive
I can't see how the broken wire in the fuse box could affect only one light and not the other. I also doubt that this is the cause of the problem.
Old Apr 10, 2015 | 01:29 PM
majorpayne317641
With intermittent voltage drops on a wire you cannot predict how the HID ballast will react as they have capacitors inside. First check this known issue then move on to other problem areas. The oem ballasts and lights are extremely reliable.
To Low Beam Flickers
