CV shaft upgrade
Old Apr 12, 2015 | 12:33 PM
timd38's Avatar
timd38
Default CV shaft upgrade
How much horsepower do you need to justify upgrading you CV shafts?
Thanks!
Old Apr 14, 2015 | 02:44 PM
5 Liter Eater's Avatar
5 Liter Eater
St. Jude Donor '11
Imo ~1000 rwhp
Old Apr 14, 2015 | 02:47 PM
subfloor@centurytrans's Avatar
Supporting Vendor
2024 C6 of the Year Finalist - Modified
2020 Corvette of the Year Finalist (track prepared)
2019 C6 of Year Winner (track prepared)
Thanks!
As with upgrading your transmission, it's not so much about horsepower as it is about overall abuse.
I ran stock axles on my car which makes around 600rwhp and the one and only time I broke an axle was when I launched the car after it had 91K street miles and at least 3000 passes at the track.
Old Apr 14, 2015 | 02:58 PM
timd38's Avatar
timd38
Thanks all! I only have 540, but am going to the drag strip to drive my car for the first time in 40 years an really don't want to beak anything. Sounds like I am Ok. Have the killer output shafts, Quaife carrier and a diff brace, but one never knows!
Thanks!
Old Apr 14, 2015 | 03:02 PM
Supporting Vendor
Thanks!
And like I said in post #5 of this thread, if you do upgrade don't use Gforce:
https://www.corvetteforum.com/forums...6&goto=newpost
Old Apr 14, 2015 | 03:07 PM
timd38's Avatar
timd38
Thansk!
The real question is if you buy C5 Z06 shafts, how do you know you are getting C5 Z06 shafts.? I think the ones you have are overkill for me, but maybe that is the way to go.
Old Apr 14, 2015 | 03:13 PM
Supporting Vendor
Thansk!
One of them has a bit of an indentation in the part that slides into the differential but I can't remember which one does. If you really need to know I can poke around my garage tonight to find out for sure.
Old Apr 14, 2015 | 03:23 PM
timd38's Avatar
timd38
Thanks! I looked at most of the common places to get them and most do not distinguish between a reg and a Z06, so my bet is that they are all regular ones.
I may just get a pair of DSS 600 HP ones and move on.
Also, wonder if I could buy a pair of axles from one of the major retailers and rebuild them using C5 Z joints. I guess it will give me something to do after dinner this evening!
Old Apr 14, 2015 | 03:44 PM
realcanuk's Avatar
realcanuk
St. Jude Donor '13
Someone will correct me if I am wrong, but I was under the impression that all C5 shafts are the same. I ordered one from the dealer and he had the same part number for the C5 and C5Z if I remember correctly.
Old Apr 14, 2015 | 04:02 PM
timd38's Avatar
timd38
Interesting! Not always sure what you get until something goes wrong!
I am finding the parts to be the same also, but I don't think they are.
Old Apr 14, 2015 | 04:05 PM
realcanuk's Avatar
realcanuk
St. Jude Donor '13
If its the same part number, than its the same part. lol.
I decided against DSS axles in the end because if anything is going to break, I would rather it be the axle. I consider it like a fuse. Fairly cheap and easy to replace compared to what else might break.
Old Apr 14, 2015 | 04:17 PM
timd38's Avatar
timd38
So you bought C5 axles from the dealer?
Old Apr 14, 2015 | 04:19 PM
realcanuk's Avatar
realcanuk
St. Jude Donor '13
Due to some strange events I had one C5 axle and one original C6. The C6 is the one that broke, and I replaced it with a C5 from the dealer.
Old Apr 14, 2015 | 08:48 PM
tuboy19's Avatar
tuboy19
I thought that too... then the axle broke and when the pressure unloaded it took the opposing side diff cover and my bell housing with it .
With that said, I have C5 axles now... they've been proven pretty stout.
Old Apr 14, 2015 | 10:09 PM
realcanuk's Avatar
realcanuk
St. Jude Donor '13
Wow, unlucky.
I have broken an axle and also an output shaft in the diff. Separate occasions and both launching at the track. No other damage caused maybe helped by axle hoops and a trans brace. I don't really know.
Old Apr 14, 2015 | 11:25 PM
rio95's Avatar
rio95
All c5 axles are the same.
Old Apr 17, 2015 | 07:00 AM
Seadawg's Avatar
Seadawg
How about C6 ZR1 axles? My understanding was that they were specifically designed to reduce drive train resonance, and be more reliable.
Does anyone have any track experience with a ZR1 axle setup?
Old Apr 17, 2015 | 07:22 AM
timd38's Avatar
timd38
I know the guy at GM that has the patent on that. They only issue is that they will not work on a pre 2009. DSS did say that they would build them for if I wanted.
To CV shaft upgrade
