Spring Tech.
Old Apr 13, 2015 | 02:12 PM
SnipeUout's Avatar
SnipeUout
Default Spring Tech.
The base coupe is not recommended to run Z06 bars as it tends to oversteer with 285 size tires. So what would happen with Z06 Front and rear springs on a base car?
Old Apr 13, 2015 | 02:28 PM
Dano523's Avatar
Dano523
Lets back this up.
What tires front and back, and what sizes.
Is this for,
Slower Autocross parking lot racing,
Daily driving on the roads,
High speed race course work?
Slow speed in a smooth parking lot, you can pan the car and get away with it.
High speed, you get the suspension too firm, and not enough tire, and you will be all over the track.
DD, you pan the car, or get it too firm, and you will not be happy as you bend rims twice a week on even small pot holes (much less having to drive around with a hemorrhoid pillow under your butt so you don't frag your back on the slightest of bumps in the road).
Old Apr 13, 2015 | 03:45 PM
CMY SIX's Avatar
CMY SIX
don't woory just ignore the engineers that designed and built the car, just like the forum engneers do, go out right now and buy everything that you can find thats not intended for your car, and let us know whart doesn't work, OK? What part of what those of us who have TOLD you, that is you should install Z51 sways and Bilstein shocks, and YOU WILL BE AMAZED!!!!! didn't you like? and then if you would like a little more you can change ONE spring as the base already has ONE spring in common with the Z51. THE Z06 HAS MANY MORE PARTS THAT ARE DIFFERENT THEN JUST TIRE SIZE THAT MAKES IT'S TOTAL OF PARTS WORK WELL TOGETHER!!! THE PEOPLE WHO BUILT THE CAR KNOW HOW IT WORKS TOGETHER! LISTEN TO THEM. you will save alot of wasted $
Old Apr 13, 2015 | 09:48 PM
SnipeUout's Avatar
SnipeUout
I read half of your post and thought geee this guy is an being a$&h0le. Thanks for at least trying to be helpful.
Old Apr 13, 2015 | 09:51 PM
SnipeUout's Avatar
SnipeUout
Originally Posted by Dano523
Lets back this up.
Is this for,
SoCal daily driving and alots of autocross. Maybe a HPDE.
Old Apr 13, 2015 | 09:59 PM
Dano523's Avatar
Dano523
Your still at the FE3 front spring swap from the base front spring,
Z-51 sway bars upgraded from the base sways,
and Bilstein Sports or Koni FSD shocks the best set up/balance system for what you are going to use the car for.
Old Apr 14, 2015 | 04:45 PM
CMY SIX's Avatar
CMY SIX
not being an *******, this is what I told you. your trying to out think the guys who built this car, the Z51 option was MADE for DD and AUTO CROSS
Old Apr 14, 2015 | 06:43 PM
timd38's Avatar
timd38
Like CMY SIX said, Z51 bars and Bilstein shocks. Great economy upgrade.
To Spring Tech.
