Oil pump Question
Old Apr 15, 2015 | 06:56 PM
meanjoe's Avatar
meanjoe
Default Oil pump Question
Anybody have the right answer here?
https://www.corvetteforum.com/forums...post1589424888
Old Apr 16, 2015 | 05:07 PM
Dano523's Avatar
Dano523
Align the center grooves when you install the pump.
The groves are are just there to equalize pressure between the front and back set and prevent a pressure build up.
So the relief slots will work if straight across or staggered, but better when the groove are straight across from each other since it a direct path instead or a staggered path.
