speedometer off
Old Apr 19, 2015 | 09:50 PM
jtdilallo's Avatar
jtdilallo
Default speedometer off
My vette's speedometer is off on the gauges and the HUD it will say im doing 30mph when im really doing like 45 I was thinking maybe the sensor needs to be replaced but if I put it in cruise control it will tell me the correct speed any thoughts to what it could be?
Old Apr 19, 2015 | 10:20 PM
Suds's Avatar
Suds
Damn, that's a new one.
Have you compared the cars speedometer to A GPS unit?
Also where is home for you?
Old Apr 20, 2015 | 03:43 AM
Dano523's Avatar
Dano523
Did someone change your dash gauge prints out in the dash or been playing with the mph/km settings???
These after market print outs allows you to use MPH setting with a Km dials number on the mph gauge, which will print out correctly in Km on the dash gauge correctly with the car set to MPH, and not have the DIC 200km max before it returns to zero to start over again (dail gauge will read correctly in KM, while the DIC will read out in mph instead).
Hence 48kilomiters is 30mph, and could be that wrong version aftermarket gauge printouts where installed on the speedo (read km to mph instead, with the DIC read out in KM since the dash is set for KM instead).
But the strange one, why is the dial switching back from one setting to the other when when the cruse control is set.
Bluntly, unplug the battery negative terminal cable for a 10 mins to do a hard reset on the system, and see if this solves the problem.
If not and no one played with the MPH calibration in the tune, and you have the OEM dials gauge printouts in play, then something is going strange with your dash gauge cluster mph/km settings.
Old Apr 20, 2015 | 05:05 PM
jtdilallo's Avatar
jtdilallo
I have not but I will now I never thought about that and cape coral, florida
Old Apr 20, 2015 | 05:11 PM
jtdilallo's Avatar
jtdilallo
[QUOTE=Dano523;1589455136]Did someone change your dash gauge prints out in the dash or been playing with the mph/km settings???
What you said kinda makes sense. I bought it about 2months ago and the guy I bought from said he keeps it in km because the speed it displays is the correct number for mph. I dont really understand all of what you said but if thats the problem how would I go about fixing that?
Old Apr 20, 2015 | 08:20 PM
Dano523's Avatar
Dano523
jtdilallo,
https://www.google.com/search?q=c6+c...AUoAg&dpr=1.25
And the trick may be if the gauge plates were changed out, finding out how made them, and if they sell you just the correct MPH plate alone.
Or if you have the stock face plates in the gauges, then maybe someone re-programmed the dash gauge assembly module for something strange in its firmware, and you will need someone to reprogram it back to OEM settings.
Old Apr 20, 2015 | 09:12 PM
jtdilallo's Avatar
jtdilallo
Reset did not work
Old Apr 20, 2015 | 10:24 PM
Gray Ghost GS's Avatar
Gray Ghost GS
"AlohaC5" Senior Member
Did the previous owner change the gear ratio without updating the new gears in the tune, which will throw off the speedometer?
Old Apr 22, 2015 | 05:06 PM
jtdilallo's Avatar
jtdilallo
[QUOTE=jtdilallo;1589459537]
I did the reset and now my traction control bexomes active whenever I drive over 40mph's
Old Apr 22, 2015 | 08:24 PM
Dano523's Avatar
Dano523
What are the size of your front and rear tires (need all three numbers off the tires, hence 245/40-18)?
Also, with a warning in the DCI now, pull the codes and post them at well here.
To speedometer off
