Cold Air Intake
Old Apr 22, 2015 | 03:57 PM
Batterycharger's Avatar
Batterycharger
Default Cold Air Intake
What is the real skinny on replacing the stock LS3 air filter and adding a CAI system? Is it worth cutting the shroud to get the outside air? I could baffle the system that is now on the car to eliminate the air in the engine compartment. Guess I have nothing better to do. Is it really worth the effort?
Old Apr 22, 2015 | 04:18 PM
lebvette's Avatar
lebvette
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18-‘19-'20-'21
I would keep the stock intake and let some cool air in. If I cut the shroud....it would not be very much and in the outside corners. Too much of a tornado in the intake area might cause your MAP system to mess up. Of course, this can be baffled out, or tuned out.
Old Apr 22, 2015 | 08:31 PM
Dano523's Avatar
Dano523
OEM air intake and filter will out flow what the Stock engine needs to pull in.
A CAI does not add HP, but retains the HP power instead.
If the car is sitting long enough for the intake to start sucking in hot air from the engine bay (not enough flowing through the engine bay to keep it cool), then the ECM will pull timing so the engine does not have detonation from the hotter air).
Note, your AIT sensor is part of the MAF sensor. I bring this up, since if the engine is not pulling in a lot of cold air to cool the sensor back down, hence the MAF is still in the engine bay cooking heat temps area, the AIT may still read that the air temp is still higher that the actual air being pulled in at initial launch).
So short of ram airing into the intake, just opening the shroud to allow some cooler air in (not enough to cause the surging) works just as well as some of the CAI intakes.
Note, don't get hung up on the ability for the after market system to flow X amount more air. As stated, the OEM intake is already out flowing what the engine needs to start with.
Old Apr 22, 2015 | 09:46 PM
C U IN REARVEIW's Avatar
C U IN REARVEIW
Op. If you decide to move forward with this....i am selling a "true cold air intake" Callaway honker cai. $250 in excellent condition.
Old Apr 23, 2015 | 01:51 AM
bobeast's Avatar
bobeast
Most so called CAI's aren't really. Pretty much all the manufacturers call theirs a CAI whether it is or not. Don't waste your money unless it is plumbed to pull cold air from outside the engine bay. Two things. Colder air is denser and will make more power. Also, as Dano mentioned. the engine computer won't pull as much timing with cooler air.
Old Apr 23, 2015 | 09:25 AM
C U IN REARVEIW
correct. systems like callaway honker, vararam, haltech
Old Apr 24, 2015 | 06:02 PM
ls1121's Avatar
ls1121
St. Jude Donor '14-'15
YES a real cold air intake is worth the effort. It is very little effort by the way.
Old Apr 24, 2015 | 07:02 PM
JDP Tech's Avatar
0JDP Tech
Former Vendor
Airaid Part # 250-230 is a good, cost effective system. It's the system we use in all of our packages.
Feel free to call, PM or email me anytime with questions.
Best regards,
Tyler
888-308-6007
Old Apr 24, 2015 | 10:24 PM
dennis50nj's Avatar
dennis50nj
Get the Vararam, I have tested it within a 10ft DA difference and gained 5mph and almost 5/10 went from 12.92 to 12.38, those who claim it stops timing being pulled is true as it lowers iat quicker, But and yes their is always one my car was professionally tuned by the best, before the vararam was added, and i had no tuning since it was added so my iat tables and timing were already tuned, and also i always let my car cool and pushed it to the line, yet i did the same routine with the vararam and seen those gains, set and broke many records with the vararam from that 12.98 to 10.62 with bolt/ons to 10.16 NA and vararam being on the top of the list, install it properly and you will see the performance and no water hydroloc or dirt getting past the filter
Old Apr 25, 2015 | 09:18 AM
Batterycharger
Default Honker
Will you take $200.00?
Old Apr 26, 2015 | 01:22 PM
Mr.Nubain's Avatar
Mr.Nubain
From: If you wanna live life on your own terms, you gotta be willing to crash and burn Florida
I love my vararam, it's amazing how it pulls on the highway, especially on a cool night/day
Old Apr 26, 2015 | 07:29 PM
Batterycharger
Default C u
Do you still have the Calloway Honker??
Old Apr 27, 2015 | 03:33 PM
Seadawg's Avatar
Seadawg
with Dano523. I went with a version of this: https://www.corvetteforum.com/forums...ke-shroud.html
Here is my HP and TQ graph on a dyno in hot sunny Florida, after several runs. The tuner was very impressed that virtually no timing was being pulled, even though the garage temp was close to 90. I verified that the MAF temp is within a couple degrees of ambient temp when moving, and it takes it while to creep up when sitting idling too, with my Dashlogic device.
Just headers and a tune on an otherwise stock 2011 LS3
Old Apr 27, 2015 | 06:40 PM
dennis50nj's Avatar
dennis50nj
And with the Vararam it keeps the IAT temps cooler and reaches the lower temps faster also pushes air in. also no gains are made on the dyno with the prop shroud or vararam with the iat and timing tables tuned its movement and 1/4 times tells the tale
Old Apr 28, 2015 | 03:59 PM
Seadawg's Avatar
Seadawg
Makes sense. And you have the time slips to prove it too!!
To Cold Air Intake
