c6 slave HELP!
Old May 3, 2015 | 09:58 PM
curtisb23's Avatar
curtisb23
Default c6 slave HELP!
Has anyone ever got a bad slave cylinder from gm out of the box? my slave in the car was leaking not sure were at if it was the slave or the fast bleed but I decided to just replace the hole thing and now I can't get the pedal to pump up at all!!
Old May 4, 2015 | 05:25 AM
Dano523's Avatar
Dano523
Originally Posted by curtisb23
Has anyone ever got a bad slave cylinder from gm out of the box? my slave in the car was leaking not sure water at if it was the slave or the fast bleed but I decided to just replace the hoke thing and now I can't get the pedal to pump up at all!!
You did not install the end connector from the master to the slave cylinder connector correctly.
Old May 4, 2015 | 06:39 AM
curtisb23's Avatar
curtisb23
It is all the way in and the clip is holding it on place, I get fluid out of the bleeder just can't get any pressure in the pedal
To c6 slave HELP!
