can and tune
Old May 4, 2015 | 04:18 PM
Mr Dee's Avatar
Mr Dee
Cruising
Default can and tune
Hello everyone I'm new to this thread.I have a quick question I've had my Corvette dyno tuned it 382 rwhp if I put a cam how much horsepower would I gain and how much does something like that cost if you could help me out I would appreciate it thanks.
Old May 4, 2015 | 08:23 PM
JakeC6Racing's Avatar
JakeC6Racing
You're question is very vague but I'll do my best to help answer it since I just installed a cam last week. The gains would greatly depend on the cam specs you go with and I'd suggest doing some research and seeing what fits your needs. The cost also depends on what supporting mods you go with. I went with a Comp Cams 230/234 cam (Spinmonster Specs), valve springs, pushrods, a new ATI harmonic balancer, a C5R timing chain, all new gaskets and seats, spark plugs and wires, etc. That package comes out to approximately $2500 installed and tuned. I also opted to add some Kooks 1 7/8 headers and catted x-pipe (around $1700 new + $300 installation). I ended up with 467whp all said and done.
Old May 4, 2015 | 10:20 PM
schpenxel's Avatar
schpenxel
St. Jude Donor '15
There's way too many variables to give you a solid answer..
What do you use the car for? What do you want out of it? Do you just want a big HP number at all costs.. something a little stronger all over.. something else?
Big cam, something in the middle, small, blower cam if you're planning on adding a supercharger later...? Sticking with stock heads?
Old May 5, 2015 | 08:07 AM
Mr Dee's Avatar
Mr Dee
Cruising
Default cam and tune
I would to like to get a little more horses from it but I love the way a good cam sounds in a car.I would like to hit a couple of tracks where im goin to run quarter mile passes this year but mostly daily driver Thanks.
Old May 5, 2015 | 09:01 PM
Suds's Avatar
Suds
I went CAI, intake manifold, big cam, headers, high flow cats and a tune. I have the NPP exhaust, so the car sounds mild until you switch the exhaust open. I spent about 8k plus tax to get 510+ whp. Car is a semi daily driver, but it has a significant rock, especially with the A/C on. Also the car will sometimes buck between 1500 and 2k rpm because of cam surge. Overall the thing is a beast and I love it for driving on the track or road coarse, which is what I wanted.
The install was done by a local shop, so with a DIY you could probably do the same in the 5k range. Plus a dyno tune.
I forgot that a pulley and colder thermostat where also installed.
Old May 5, 2015 | 09:17 PM
schpenxel's Avatar
schpenxel
St. Jude Donor '15
Cam surge/bucking is very possibly a tuning issue and not something you should have to live with with the right tuner.
How big is the cam?
Old May 5, 2015 | 09:30 PM
Suds's Avatar
Suds
Cam lift in the .620's.
Old May 6, 2015 | 01:55 PM
Mr Dee's Avatar
Mr Dee
Cruising
I found two shops in fresno california depending on what I want done 1700 to 2500 dollars does that sound about right.thanks for all the help.
Old May 6, 2015 | 02:15 PM
schpenxel's Avatar
schpenxel
St. Jude Donor '15
What does it include?
Old May 7, 2015 | 07:00 PM
ptroxx's Avatar
ptroxx
From: Henderson Nv-Rohnert Park/Sonoma C o. ca/born in NY Rockaway Beach.
If I were you I would talk to Rick at Synergy in Livermore for your tune and cam install... Or Abel Chevy(Richie) for install and Rick for the tune....
Old May 8, 2015 | 11:41 AM
Mr Dee's Avatar
Mr Dee
Cruising
Rick is the one that actually did the tuning on it at S&S performance that guy really knows his stuff thanks a lot I'll give them a call.
Old May 8, 2015 | 11:44 AM
LD85's Avatar
LD85
Here is pricing from Indianapolis, and my guess on the gain is @ 25-30 RWHP depending on the cam and current upgrades
Camshaft Swap Installed Package $2195
Includes all of the following:
Choice of any 54-000-11 series Comp Cam either shelf or custom ground.
.650" Lift Dual valve spring kit.
Comp 7.400” moly pushrods.
GM timing cover gasket.
GM timing cover seal.
GM water pump gaskets (2).
GM crank bolt.
Complete Installation and Full Chassis Dyno & Road Tune
Add for LS2 Timing Chain $150
Add for 25% Underdrive Pulley & Belt $299
Add for new GM Oil Pump $149
Add For Dry Sump LS3 Engines $350
To can and tune
