Ls2/LS3/LS7 parts compatibility
Old Jun 8, 2015 | 11:52 AM
400HPZ51's Avatar
400HPZ51
Default Ls2/LS3/LS7 parts compatibility
At some point in the future I'm sure I'll want to start modifying/upgrading the engine and related parts. My car currently has a LS2. I'd like to start keeping an eye out for some decently priced used parts as they come along and then store them until I'm ready to do all the engine mods. What parts cross over between platforms? Any?
Examples... Will LS3 heads work on a LS2 block? Will LS2 heads fit on a LS3 block? Can a LS3 engine/block be reasonably easily swapped into a car that originally had a LS2?
Old Jun 8, 2015 | 02:57 PM
timd38's Avatar
timd38
This book will help you. Not a simple answer.
http://www.amazon.com/Engine-Buildup...ges/B00E5D5XHI
Old Jun 8, 2015 | 06:06 PM
JaimeVrod's Avatar
JaimeVrod
LS2 heads have cathedral intake ports.
LS3 heads have rectangular intake ports.
LS7 heads even larger rectangular ports.
You can swap the heads between blocks but you have to use the corresponding intake manifold.
There are other differences as well, like rocker arms, exhaust port location (on LS7), piston to valve clearance, valve to cylinder bore clearance, fuel rail set up, etc.
In summary your combo has to be well thought out. Generally you can't run LS7 heads on a LS2 block because the valves will interfere with the cylinder wall. You could run LS3 heads on the LS2 block but will lose some piston to valve clearance thus limiting your choice of cam.
Instead of trying to put together a combination from parts that were not specifically engineered to work with each other, first determine you goal and budget (revise goal if necessary) and then choose the route to achieve your goal within the budget.
Old Jun 29, 2018 | 01:34 PM
VenomousDuck's Avatar
VenomousDuck
To whomever knows, are cams for the LS2 & LS3 interchangeable?
If not, can they be modified so that they are, and if so, how?
I have a 2009 LS3; and I want to cam it
Old Jun 29, 2018 | 02:45 PM
Evo_Joe's Avatar
Evo_Joe
Get a custom grind cam from BTR (Brian Tooley) or Guerra Group (Pat G)
Old Jun 29, 2018 | 02:55 PM
irok's Avatar
irok
yes they are interchangeable
Old Jun 29, 2018 | 04:19 PM
Evo_Joe's Avatar
Evo_Joe
single vs three bolt?
05-06 vs 07+?
Old Jun 29, 2018 | 04:27 PM
farmington's Avatar
farmington
The cams are physically interchangeable, but generally, motors with the rectangular port ls3 heads will use Cams with a little more exhaust duration.
Old Jun 30, 2018 | 12:36 PM
irok's Avatar
irok
05-06 vs 07+?
Your choice.I prefer 3 bolt.any year is good
Old Jun 30, 2018 | 02:03 PM
VenomousDuck
Awesome, thanks guys
yall ever heard of anyone actually doing a cam swap with the block still in the car?
I used to be a mechanic (for GM actually) and I know it looks impossible with all the **** crammed into the front of the engine bay
BUT, I also that all cars have their little idiosyncrasies that make certain jobs a nightmare; and others not nearly as hard as they look at first
can the engine be tilted or jacked up or anything like that that isn’t super obvious to new owners like me?
Old Jun 30, 2018 | 02:05 PM
VenomousDuck
funny; it was a Chevy article in which they dyno’d 3 Tooley cams that brought me here
Old Jul 1, 2018 | 07:30 AM
Curt D's Avatar
Curt D
No need to mess with the block at all. There are some threads with pics on swapping the cam.
Old Jul 1, 2018 | 09:13 AM
Red06Vette's Avatar
Red06Vette
Cam swap can be done without moving engine, need to remove steering rack.
, A/C condenser coil can also be moved without disconnecting. If you're an auto, removing balance is a little more difficult than with a stick.
Attached is a document I was given back in 2010 for my cam swap, I hope the original author doesn't mind, this will give you an idea what's involved.
File Type: doc
To Ls2/LS3/LS7 parts compatibility
